| New Reply |
Help Design a Human-Powered Helicopter |
Share Thread | Thread Tools |
| Dec3-09, 03:21 PM | #69 |
| Dec3-09, 06:49 PM | #70 |
| Dec3-09, 07:15 PM | #71 |
| Dec3-09, 09:51 PM | #72 |
Recognitions:
[EDIT] OK. So I did some looking after writing that, and found some references that disprove what I wrote. Seddon shows a theoretical expression (making a few major assumptions) that seems to work well in most cases: [tex]\left[\frac{T}{T_\inf}\right] = \frac{1}{1-\frac{R}{4Z}^2}[/tex] This is supported by Figure 7 from Knight and Hefner: http://naca.central.cranfield.ac.uk/...aca-tn-835.pdf I also found this graphic which I am kicking myself because I have seen this before (a longggggg time ago) ![]() So it's not exponential, but it does decrease with increasing Z/R ratio. I stand humbly corrected. |
| Dec3-09, 09:51 PM | #73 |
To continue with this unspirited concept, it occurs to me that it might be equally beneficial to have 'ceiling' effect to double things up. I'm not sure if this makes sense. Edit: I've re-read the rules, and the spirit erules to eliminate hovercraft and other stuff outside the intended box). But to be fair, all these attempts would have exploited ground effect. |
| Dec3-09, 10:32 PM | #74 |
| Dec4-09, 12:06 AM | #75 |
| Dec4-09, 06:02 AM | #76 |
"Why on earth would you do such a thing? Think of it this way, what do you think will happen to the stresses at the hub when you suddenly dump the collective?"
the main reason is that the total accumulated work over time is "banked" in an hour or two of "run up" in order to have momentum help to keep the rotors going with the available power from the pilot. Isn't the changing angle of attack what causes a conventional "rotor'd craft" to fly? If so, why in this application it assembly would self destruct? dr |
| Dec4-09, 08:58 AM | #77 |
| Dec4-09, 11:56 AM | #78 |
| Dec4-09, 12:04 PM | #79 |
| Dec4-09, 01:16 PM | #80 |
| Dec4-09, 02:01 PM | #81 |
Mentor
| Dec4-09, 02:03 PM | #82 |
Mentor
| Dec4-09, 03:16 PM | #83 |
What you could not do, is spin them up, and have someone else jump in and then take off. Or, store energy in a spring, and then come back an hour later and try to fly after you are refreshed, along with the help of the spring. |
| Dec4-09, 03:41 PM | #84 |
| Dec4-09, 10:25 PM | #85 |
| New Reply |
| Thread Tools | |
Similar Threads for: Help Design a Human-Powered Helicopter
| design a human-powered machine... | Introductory Physics Homework | 5 | ||
| Solar Powered Helicopter? | Aerospace Engineering | 31 | ||
| Human powered circumnavigation | Earth | 0 | ||
| Human powered still - Nichrome wire | Electrical Engineering | 6 | ||
