| New Reply |
Solar cell phone charger |
Share Thread | Thread Tools |
| Sep19-09, 10:57 PM | #1 |
I'm planning on making a simple solar powered cell phone charger for a demonstration speech in my gen-ed speech class because it seemed like it would be fun at least. The best solar panel I could find for cheap has an output of 6v and 50 mA. My cell phone charger has an output of 5.0v and 700 mA.
Now my question is do I need to use a resistor to lower the voltage of the solar panel, and if I do I assume the output current will be even lower, and will it even cause the cell phone to say it is charging? I imagine it would take forever but as long as it says its charging thats good enough. I could probably afford another one and hook them up in parallel if you think that would help. Also, out of curiosity, if you used 4 AA batteries in serial to get 6v, would you need to use a resistor to get it to 5v and, if you did, what would be the output current afterwards? Thank you for your help! |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep19-09, 11:15 PM | #2 |
Recognitions:
Using a resistor is tricky because it depends on the resistence of the phone charger circuit
You are probably OK feeding it 6V - but a fixed 5v output regualtor is very easy to use. |
| Sep20-09, 01:33 AM | #3 |
Im sure you can find a better solar cell in an electronics store with at least 500 mA.
| Sep20-09, 06:51 PM | #4 |
50mA is really low. If you decide to use the one you're already looking at then just put a diode in series with it to drop the voltage down to about 5.6ish volts and it should work fine.
| Jun24-11, 10:42 PM | #5 |
sir can i see your circuit design...so that i have a reference about solar panel design cicuit for my thesis.
| Jun29-11, 05:38 PM | #6 |
Mentor
This is a 2 year old thread.
Here are tons of cheap solar cell phone chargers. http://www.google.com/search?sourcei...+phone+charger |
| New Reply |
| Thread Tools | |
Similar Threads for: Solar cell phone charger
| Current sensor needed to monitor solar cell while cell is being used. | Electrical Engineering | 11 | ||
| fyp : 12v solar charger | Electrical Engineering | 4 | ||
| battery charging of cell phone using solar energy | Electrical Engineering | 2 | ||
| cell phone rings near any type of powered speaker I can hear clicks in my speakers | General Engineering | 11 | ||
| Will this 2.2 watt solar charger charge my booster pack? | Computing & Technology | 2 | ||
