| Thread Closed |
Molar mass to molecular formula |
Share Thread | Thread Tools |
| Sep20-09, 03:00 AM | #1 |
The empirical formula of a compound is C3H2O. If the molar mass of this compound is 192.8, what is its molecular formula? 1. C12H8O4 2. C7H4O 3. C9H6O3 4. C15H10O5 2. Relevant equations 3. The attempt at a solution I'm having trouble with this question, I am not getting a whole number value for mass so I don't know what to do. I did this: 3C->36g , 2H -> 2g , O -> 16 g, TOTAL: 54g Compound: 192.8. 192.8/54 = 3.57. Therefore, I guess it could be a or b as an answer, but I don't know what to do. Can someone help? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep20-09, 03:37 AM | #2 |
Admin
Is it possible that C7H4O is the molecular formula?
-- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Sep20-09, 12:28 PM | #3 |
Yes that is one of the answers, is that the correct one?
Can you briefly explain how you got it please? Thanks. |
| Sep20-09, 02:56 PM | #4 |
Recognitions:
You want as close to a whole number quotienta as you can find. You only used one unit of "192.8". You could try other counts of "192.8", as long as you test whole number values.
Borek, somehow I do not like the choice of C7H4O. Can you support this choice? |
| Sep20-09, 04:26 PM | #5 |
Admin
You misunderstood my question, but I see now that what I posted could be confusing.
What I meant was: can this answer can be a correct one, if the emprical formula is C3H2O? -- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Sep20-09, 06:21 PM | #6 |
This is a general chemistry class I'm taking, I'm in my freshman year of college. The questions have been wrong a couple times before in previous assignments (and we've only had 2 previous assignments) so it may be a problem with the question. I will email the professor for more information. The assignment is due this Tuesday so I still have time. Thanks for your help so far. |
| Sep20-09, 06:25 PM | #7 |
Admin
There is a simple rule that molecular formula must follow if empirical formula is known.
-- ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator www.ph-meter.info - ph meter, ph electrode |
| Sep21-09, 09:36 PM | #8 |
Just to give an answer to this question, my professor told me to round the ratio to the nearest whole number. Since it was 3.57 I should round it to 4, thus the correct answer would be C12H8O4.
| Sep21-09, 10:17 PM | #9 |
Recognitions:
| Sep22-09, 10:07 PM | #10 |
definitely a problem with the question itself. molecular formulas need to be exactly integer multiples of empirical formulas, and 3.5 isn't close enough to an integer value to count. tell them to rerun the mass spec data lol.
| Sep22-09, 10:12 PM | #11 |
Thanks guys, I'll keep it in mind for next time. Either way, I got the question correct, so you guys helped a lot.
My professor actually went on to say during next class that we could round up or down and she would count either as correct. Also she stated that the ratio was inaccurate, but those are the type of values we can expect to get in real life. |
| Sep23-09, 01:40 AM | #12 |
Recognitions:
iwin2000 lastly wrote:
| Sep23-09, 01:51 AM | #13 |
| Sep23-09, 01:56 AM | #14 |
Recognitions:
Now, dig this!
choice 1: 216.196/54 = 4.0036 (did I do something wrong? used software calculator Win.) choice 3: 162.147/54 = 3.0027 choice 4: 270.245/54 = 5.045 Unless I did something wrong, choice #1 or #3 seems to be the best. Distinguishing does not seem significant. |
| Sep23-09, 02:05 AM | #15 |
| Sep23-09, 02:08 AM | #16 |
now that i think about it, the bad mass is probably due to not purifying the sample enough and using an impure sample in combustion analysis.
| Sep23-09, 02:32 AM | #17 |
Admin
Note, that a lot depends on the method of determining molar mass, so 192.8 g/mol can be a honest result, one that needs refining. Imagine using ebuliometric or crioscopic method to determine molar mass of substance that dimerizes to some extent in the solution. You didn't know that beforehand, all you know is that molar mass is off and you have to deal with it somehow. -- chemical calculators - buffer calculator, concentration calculator www.titrations.info - all about titration methods |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Molar mass to molecular formula
| mass times avogadro's numbers = molar mass ?? | Biology, Chemistry & Other Homework | 2 | ||
| how to find the molecular formula out of the molar mass? | Biology, Chemistry & Other Homework | 2 | ||
| molecular formula | Biology, Chemistry & Other Homework | 1 | ||
| molecular formula | Biology, Chemistry & Other Homework | 2 | ||
| from empirical formula to molecular formula (need help) | Biology, Chemistry & Other Homework | 6 | ||
