Find the normal force and magnitude of acceleration.
The problem involves a block being pushed up a frictionless incline, requiring the calculation of the normal force and the magnitude of acceleration. The incline makes a specific angle with the horizontal, and gravitational acceleration is provided.
  • Participants discuss the relationship between forces acting on the block, including the normal force and gravitational force. There are attempts to apply Newton's second law and trigonometric functions to find the necessary values. Questions arise regarding the correctness of initial calculations and the method for determining the normal force.
Some participants are providing guidance on the relationship between the normal force and the incline, while others are exploring the calculations for acceleration. There is an ongoing examination of the assumptions related to angles and force components, but no consensus has been reached on the correct values or methods.
Participants are working within the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a focus on rounding answers to specific significant figures as per the problem's requirements.
sonutulsiani
A horizontal force of 100 N pushes a 12-kg block up a frictionless incline that makes an angle of 25° with the horizontal. (Use g = 9.81 m/s2.)
1. What is the normal force, in Newtons, that the incline exerts on the block? Round your answer to two significant figures.
2. What is the magnitude of the acceleration of the block in m/s2? Round your answer to one decimal place.
F=ma
a=dv/dx
1. I got it as 117.72. Is it right? And if it's right how do I round to 2 significant figures.
2. I don't know how to find acceleration.
For the first one, remember that the normal always make a 90 degree angle with the surface. So your first result is not correct.
The second question is best solved using the normal force, the horizontal force, some trigonometry and Pythagoras. Try to solve the first one, and then you can get further help with the second question.
What I did is F=ma => F=12*9.81m/s^2
How do I substitute 90 degree in that?
|a\
Know that gravity works strait down and figure out the angle a, then use appropriate trigonometric functions to calculate the answer. The non-strait-down line in the sketch is the normal.
I got the acceleration as 56.9 m/s^2 Is it right?
But I still can't find what's normal force.
  • · Replies 37 ·
  • · Replies 95 ·
