Trouble with use of the Residue Theorem
  • Context: Graduate
  • Thread starter Thread starter jeffreydk
    Residue Theorem
The discussion focuses on the application of the Residue Theorem to evaluate the integral \(\int_{0}^{\infty}\frac{dx}{x^3+a^3}\), yielding the result \(\frac{2\pi}{3\sqrt{3}a^2}\). The user initially miscalculated the integral along the ray at \(\theta=\frac{2\pi}{3}\), leading to an incorrect conclusion that the integral should equal \(-\frac{2\pi i e^{i\pi/3}}{3a^2}\). A crucial insight was provided regarding the non-zero contribution of the integral along the ray, which corrected the user's approach to include the constant \(C\) in the closed integral equation.
  • Understanding of complex analysis, specifically the Residue Theorem.
  • Familiarity with contour integration and parametrization techniques.
  • Knowledge of evaluating integrals involving poles and residues.
  • Basic proficiency in handling complex exponentials and trigonometric identities.
  • Study the application of the Residue Theorem in complex contour integrals.
  • Learn about parametrization methods for complex integrals, particularly in the context of rays and arcs.
  • Explore the properties of poles and residues in complex functions.
  • Investigate the use of trigonometric identities in complex analysis, such as the relationship between sine and exponential functions.
Students and professionals in mathematics, particularly those specializing in complex analysis, as well as anyone seeking to deepen their understanding of the Residue Theorem and its applications in evaluating integrals.
jeffreydk
I have just learned the residue theorem and am attempting to apply it to this intergral.
[tex] \int_{0}^{\infty}\frac{dx}{x^3+a^3}=\frac{2\pi}{3\sqrt{3}a^2}[/tex]
where [itex]a[/itex] is real and greater than 0. I want to take a ray going out at [itex]\theta=0[/itex] and another at [itex]\theta=\frac{2\pi}{3}[/itex] and connect them with an arc at infinity to evaluate the integral using the residue theorem; but so far I am having problems getting the correct result. I have shown
[tex]\left|\frac{1}{x^3+a^3}\right|=\frac{1}{|x|^3}\frac{1}{\left|1+\frac{a^3}{x^3}\right|}\leq \frac{1}{|x|^3}\frac{1}{\left|1-\frac{|a|^3}{|x|^3}\right|}[/tex]
by the triangle inequality. If we can say that [itex]\frac{|a|}{|x|}<\frac{1}{2^{1/3}}[/itex] then it follows that
[tex]\left| \int_{\text{arc}}\frac{dx}{x^3+a^3}\right|\leq \left(\frac{2\pi R}{3}\right)\frac{2}{R^3}=\frac{4\pi}{3R^2}\longrightarrow 0[/tex]
Thus the arc integral goes to 0 as the radius become infinite as needed. For the ray along [itex]\theta=\frac{2\pi}{3}[/itex] using a parametrization of [itex]x=(R-t)e^{2\pi i/3}[/itex] which gives [itex]dx=-e^{2\pi i/3}dt[/itex] the integral becomes
[tex]\int_{\text{ray}_2}\frac{dx}{x^3+a^3}=\int_{\text{ray}_2}\frac{-e^{2\pi i/3}dt}{(R-t)^3e^{-2\pi i}+a^3}\longrightarrow 0[/tex]
again as needed. This would mean to me that the integral should just be the sum of residues lying inside my contour (times [itex]2\pi i[/itex] of course), which is just the one pole [itex]x=ae^{i\pi/3}[/itex]. This would give
[tex]\text{Res}f(ae^{i\pi/3})=\lim_{x\rightarrow ae^{i\pi/3}}(x-ae^{i\pi/3})\left(\frac{1}{x^3+a^3}\right)=-\frac{e^{i\pi/3}}{3a^2}[/tex]
and since it is a first order pole this is also the residue. Therefore the answer I am getting is
[tex]\int_{0}^{\infty}\frac{dx}{x^3+a^3}=-\frac{2\pi i e^{i\pi/3}}{3a^2}[/tex]
I'm not sure where I went wrong--any help would be greatly appreciated.
Your residue is right, but you should know that the integral along z/|z|=exp(2*pi*i/3) is not zero.
let I be the given integral
You will see
ray integral=C*I (for some costant C find it)
then
closed integral=given+arc+ray=(1-0-C)*I=2pi*i*res(f,z0)=-2pi*i*exp(2pi*i/3)/(3a^2)
recall
sin(z)=[exp(iz)-exp(-iz)]/(2i)
Ah! Thank you very much for that insight, it hit me as soon as I read what you had to say. I haven't used that trick in awhile so I think I temporarily forgot about it.
  • · Replies 29 ·
