Field of non-uniformly charged ring
The problem involves calculating the electric field created by a thin rubber ring with a non-uniform line charge density on points along the positive z-axis. The charge density is defined as λ=λo*sin(Ø), and the setup is in the xy-plane with the ring centered at the origin.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the symmetry of the electric field components, noting that only the z-component should be non-zero along the z-axis. There are attempts to integrate over the angle Ø, with some questioning the limits of integration and the proper expression for the charge element dq. Others suggest that a visual representation may aid in understanding the problem setup.
There is an ongoing exploration of the problem, with some participants offering insights into the symmetry and charge distribution. A few have pointed out potential mistakes in the calculations and the need to correctly identify the components of the electric field. While some guidance has been provided, there is no explicit consensus on the final outcome.
Participants are navigating the complexities of integrating a non-uniform charge distribution and are addressing the implications of symmetry on the electric field components. There is an acknowledgment of the need to clarify definitions and assumptions related to the charge density and the geometry of the problem.
skyrolla
A thin rubber ring of radius R lies in the xy-plane and is centered at the origin. The ring carries line charge density λ=λo*sin(Ø), with a constant λo with units C/m. define tan(Ø)=y/x. Calculate the magnitude and direction of the electric field E(z) created by the ring on points on the positive z axis.
E=kq/r^2
Symmetry implies only the component Ez will be nonzero along the z axis.
Desiring to integrate over Ø, my limits of integration will be 0 to pi.
Now dE=k*dq/r^2 with r=(R^2+z^2).
Q/R=λo*sin(Ø) so dQ=R*λo*cos(Ø) dØ
and dEz= k*R*λo*cos(Ø) dØ/(R^2+z^2)
however, integrating this over Ø results in multiplying everything by sin(pi)-sin(0) = 0, so clearly I've made at least one mistake here.
All help is appreciated!
the result must be zero for the sake of symmetri. Your result is correct (I think)
Symmetry in the x and y directions makes sense, as an equal amount of ring and angle phi are distributed to both the positive and negative halves. However the field would certainly have a Z component at points along the Z axis, as the full ring exerts charge in either a positive or negative z direction.
the charge is ditributed in iqual amount in each semi-circle but with defferent signs, so symmetry implies that the z component must be zero. However I now realize that there must be a component in the x-y plane
I think you should draw a picture...the angle [tex]\phi[/itex] is measured entirely in the xy-plane, and any point on the ring is given by [itex]x=R\cos\phi[/itex], [itex]y=R\sin\phi[/itex] and [itex]z=0[/itex].<br /> <br /> If the ring is an entire circle, the limits on [itex]\phi[/itex] will be zero to [itex]2\pi[/itex]<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Now dE=k*dq/r^2 with r=(R^2+z^2). <br /> <br /> Q/R=λo*sin(Ø) so dQ=R*λo*cos(Ø) dØ </div> </div> </blockquote><br /> Not quite. By definition of linear charge density, [itex]dq=\lambda ds=\lambda_0 \sin\phi Rd\phi[/itex]<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> and dEz= k*R*λo*cos(Ø) dØ/(R^2+z^2) </div> </div> </blockquote><br /> No, not only should the cosine be a sine, but you haven't properly selected the z-component of [itex]d\textbf{E}[/itex].<br /> <br /> Again, draw a picture...the field [itex]d\textbf{E}[/itex] from a tiny piece of the ring points from that piece, to the point on the z-axis at which it is measured...you want to find the z-component of that vector.<br /> <br /> Even after you do the calculation properly, you will still find that [itex]E_z=0[/itex], however, if you also calculate the other components you should find that [itex]E_y\neq0[/itex].[/tex]
Thanks. After figuring out I had the wrong component, I was able to solve the problem.
  • · Replies 19 ·
  • · Replies 16 ·
