| Thread Closed |
Probability involving coin flips |
Share Thread | Thread Tools |
| Sep21-09, 04:07 PM | #1 |
We are flipping a coin with probability p of getting heads n times. A "change" occurs when an outcome is different than the one before it. For example, the sequence HTHH has 2 changes. If p=1/2 what is the probability that there are k changes? 2. Relevant equations I've been working with the probability mass function of a binomial random variable: (n C k) pk(1-p)n-k 3. The attempt at a solution For the n flips there are n-1 possible "gaps" between flips when change could occur. I then reasoned that at the end of every flip since you a flipping a fair coin, there is a 1/2 chance of getting a change and a 1/2 chance of not getting a change. My resulting formulation for probability of k changes in n flips was: (n-1 C k)((1/2)k)((1/2)n-k) but I worked out explicitly the probabilities of k changes for n=2, 3, and 4 and this function did not give me at all correct answers. I'm not sure how I should approach it differently. |
| Sep21-09, 04:37 PM | #2 |
Recognitions:
You've the right idea with (n-1 C k) counting the numbers of ways to get k flips in n throws in terms of where it flips. So how many total ways are there of throwing the coin n times and getting k flips? Now how many ways of throwing the coin n times without that restriction? Isn't the ratio going to be the probability?
| Sep21-09, 04:53 PM | #3 |
"So how many total ways are there of throwing the coin n times and getting k flips? "
I say it's (n-1 C k) again. "Now how many ways of throwing the coin n times without that restriction?" 2n So this would give (n-1 C k)/2n, but when I run it against my calculated probabilities this gives half the value of the original answer. So it seems I should multiply by 2 in the formula. Not sure how to justify that though. Is it because you can have changes from H to T and T to H? |
| Sep21-09, 05:03 PM | #4 |
Recognitions:
| Sep21-09, 07:35 PM | #5 |
Okay that was my line of reasoning. I just wanted to be sure I wasn't making a major miscalculation.
Thanks very much for your clear explanation. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Probability involving coin flips
| Infinite coin flips, etc. | Set Theory, Logic, Probability, Statistics | 3 | ||
| Coin flips problem | Set Theory, Logic, Probability, Statistics | 3 | ||
| Expected Number of Coin Flips | Set Theory, Logic, Probability, Statistics | 4 | ||
| 4 flips of a fair coin | Set Theory, Logic, Probability, Statistics | 5 | ||
| Probability of Same face in Coin flips | Calculus & Beyond Homework | 2 | ||
