Continuous Function Problems AP Calculus
The problem involves determining the positive values of a for which the function f(x) = (x-1)(x²-4)/(x²-a) is continuous for all real numbers x. The subject area is calculus, specifically focusing on the continuity of functions.
  • Exploratory, Assumption checking
  • Participants discuss the continuity of polynomials and the implications of products and quotients of continuous functions. There is an attempt to factor the function and explore the conditions under which it remains continuous.
Some participants have offered hints regarding the properties of continuous functions, while others have suggested specific values for a based on their reasoning. The discussion is ongoing, with various interpretations being explored without a clear consensus.
Participants are navigating the constraints of the problem, particularly regarding the cancellation of terms in the function and the implications for continuity. There is an emphasis on adhering to the rules of calculus in the context of the homework assignment.
Loppyfoot
Let f be the function given by f(x)= (x-1)(x²-4)/ (x²-a). For What Positive Values of a is f continuous for all real numbers x?
What I tried doing was separating the (x²-4) into (x+2)(x-2) then moving along from there, but I can't seem to figure out what number a can be without having a discontinuity.
Thanks for trying!
Loppyfoot
Hint:
1. Are polynomials continuous?
2. Are products of continuous functions continuous?
3. Are quotients of continuous continuous?
Are any of the answers above valid for all values of x or are any of them subject to some "if" conditions?
So Then, I would guess a=4, because the the (x²-4) and the (x²-4) cancel out and you are left with (x-1).
You aren't permitted to cancel anything out since that makes minor changes in the function. Try answering the three questions I posed. That might lead you to the solution.
  • · Replies 40 ·
  • · Replies 27 ·
  • · Replies 20 ·
