How to find radius if I know angle and velocity
  • Context: High School
  • Thread starter Thread starter chiarama
    Angle Radius Velocity
The discussion revolves around calculating the radius of a turn for an RC car based on the angle of the front wheels and the car's velocity. Participants explore the relationship between these variables and the geometry of the car's movement during a turn.
  • One participant seeks to calculate the radius of the turn using the angle of the wheel and the car's velocity, recalling concepts from a physics class.
  • Another participant clarifies the distinction between the radius of the arc of the turn and the radius of the wheel.
  • A participant proposes that the radius of the turn is determined by the angle of the wheel, the length of the car, and suggests a formula: r = 1/(le*tan(thetaw)), while noting that velocity does not directly determine the radius.
  • There is a discussion about the translational velocity of the wheels versus the car's velocity during a turn, with one participant stating that the effective velocity is v*cos(thetaw).
  • Another participant expresses uncertainty about the proposed formula and requests clarification on how it was derived, while also questioning the meaning of the car's length in this context.
  • One participant mentions that their own calculations yield a different result, suggesting that the length of the car is proportional to the radius, and raises a question about the comparative turning radii of different vehicles.
  • Concerns are raised regarding the dimensional analysis of the proposed formula, questioning the validity of the units involved.
Participants express differing views on the relationship between the angle of the wheel, the car's velocity, and the radius of the turn. There is no consensus on the correct formula or approach to calculate the radius, and multiple competing models and interpretations are presented.
Participants acknowledge assumptions made in their reasoning, and there are unresolved questions about the definitions and measurements involved, particularly regarding the length of the car and the implications of the proposed formulas.
chiarama
I'm designing RC car and need to know the radius of circle when I drive corner.
I know the angle of the wheel and car velocity.
how can I calculate? I think I learned about it in the general physics class but I don't remember.
Radius of the arc of the turn or radius of the wheel?
radius of the arc of the turn. Thank you for interest!
When you said angle of wheel, I'm assuming the angle of the front wheel is turned in order for turning the car.
I made assumptions here and there, and so according to experience, there is a good chance I made some mistakes. According to what I got, the velocity does not determine the radius of the curve, but the angle of the wheel, thetaw, and the length of the car, le, do (so you'll need an additional measurement). Also, the translational velocity of the wheels is not the translational velocity of the car while turning - I got v*cos(thetaw) for that value (disregarding friction while turning). What I got for the radius was r = 1/(le*tan(thetaw)). If anyone could confirm/correct it, it'd be helpful.
I tried to prove your answer but I couldn't. can you explain how you got that result?
And when you mention the length of the car, do you mean distance between center of front and rear wheel?
Yup.
The car movement could be modeled as an arc of a circle. With a constant speed the centripetal acceleration is a = v2/r. Usually when referring to cars in circular motion, it is said that the static friction provides the centripetal force (otherwise there will be kinetic friction and the car speeds in a tangent). However, the car does not have to be in circular motion to experience static friction, so more directly or indirectly, what is allowing for the the motion is the turn/angle of the wheel. What I did was I first just focused on the car as my system (you can draw it out as a line that is moving forward with a velocity v, in which the length of the line is the length of from the rear wheel to the front wheel). In this situation, the only wheels turned are the front wheels; therefore, the velocity at the front of the car/line is at an angle to the car/line, so part of the velocity is in the forward direction of the car and part is in the perpendicular direction. Since the rear wheels are focused on the ground by static friction, you could look at it as the line moving forward with a velocity equivalent to the component in the forward direction (v*cos(thetaw)) and rotating due to the component perpendicular to the car (v*sin(thetaw)). As the line rotates, the forward direction changes - altogether, you have the car moving in an arc. The angular velocity of the rotation of the car is negative the angular velocity of the revolution of the car. The centripetal acceleration is also a = v*w (w is the angular velocity of the revolution and v is the tangential velocity, which is v*cos(thetaw )). With that, you can solve for the radius. Of course, I might also be wrong about this.
Thank you for your answer!
I also tried to solve this problem in my way and got different result with yours. in case of my result, length of the car is proportional to the radius.
when we think about bus and car, which one has smaller radius when turn? its confusing..lol
and when we think about the dimension, if we have 1/le in the result, it will be 1/m which is incorrect...
  • · Replies 20 ·
  • · Replies 60 ·
  • · Replies 28 ·
  • · Replies 30 ·
