What is the Angle and Normal Force in a Towing Scenario?
  • Thread starter Thread starter bolivartech
    Angle Force
The problem involves a woman towing a suitcase at a constant speed using a strap pulled at an angle. The suitcase has a mass of 20.0 kg, and the forces acting on it include a pulling force of 35.0 N and a friction force of 20.0 N. The questions focus on determining the angle of the strap with respect to the horizontal and the normal force exerted by the ground on the suitcase.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss breaking down the pulling force into its x and y components and relate these to the forces acting on the suitcase. There is an exploration of the conditions for constant velocity, leading to questions about the resultant horizontal force.
Some participants have provided insights into the relationships between the forces, particularly in the x-direction, and have suggested equations to find the angle θ. There is ongoing exploration of the normal force in relation to the weight and the vertical component of the pulling force.
Participants are considering the implications of the suitcase being towed at constant speed, which influences the net forces acting on it. There is a focus on ensuring all components of the forces are accounted for in the analysis.
bolivartech
A woman at an airport is towing her 20.0-kg suitcase at constant speed by pulling on a strap at an angle θ above the horizontal (Fig. P5.40). She pulls on the strap with a 35.0-N force. The friction force on the suitcase is 20.0 N. Draw a free-body diagram of the suitcase. (a) What angle does the strap make with the horizontal? (b) What normal force does the ground exert on the suitcase?
F - fk = ma
W = mg
(a) F - fk = ma
35.0 N – 20.0 N = (20.0 kg)(sinѲ)(9.8 m/s2)
sinѲ = (15.0 N) / (20.0 kg)(9.8 m/s2)
Ѳ = sin-1[(15.0 N) / (20.0 kg)(9.8 m/s2)]
Ѳ = °
(b) W = mg
W = (20 kg)(9.8 m/s2)
W = 196 N
I don't know if what I attempted was even on the right path. Could someone point me in the right direction? Thanks!
the 35N at an angle of θ, has what x and y components?
It says it pulls at constant velocity which means the resultant horizontal force is what?
y = 35N sinθ
x = 25N cosθ - 20N
bolivartech said:
y = 35N sinθ
x = 35cosθ
So now
in the x direction the resultant force is zero so what is the equation for this sum of the forces in the x direction? You can find θ now.
sorry that was a typo
so
0 = 35N cosθ - 20N
20N / 35N = cosθ
θ = cos^-1 (20N / 35N) = 48.19
I really over complicated that. I need to remember to make sure I see all the parts before I begin. Can you tell me if I did the second part correctly? The normal force is the opposite of W since it is not moving in the Y direction right?
bolivartech;2361265 I really over complicated that. I need to remember to make sure I see all the parts before I begin. Can you tell me if I did the second part correctly? The normal force is the opposite of W since it is not moving in the Y direction right?[/QUOTE said:
ok well you should remember that the force she is pulling with has a vertical component of 35sinθ which points upwards just like the normal reaction (R).
The sum of these two = weight.
I think you can find R now.
Got it, thanks!
  • · Replies 21 ·
