Thread Closed
Showing union of open sets is an open set?
Share Thread Thread Tools
Sep23-09, 12:01 AM   #1
Let U_n = {all p = (x, y) with |p - (0, n)| < n}. Show that the union of all the open sets U_n, for n = 1, 2, 3, ..., is the open upper half plane.
2. Relevant equations
3. The attempt at a solution
U_n describes points p whose distance from a set point on the vertical axis is smaller than the height of that point that is on the vertical axis. When you move the vertical axis point up and down, and combine all the sets of points created, you'll get the upper half plane not including the horizontal axis. I can picture it, but how do I begin to show it?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep23-09, 01:07 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Pick a point in the upper half plane p=(x,y) with y>0. Can't you figure out a way to find an n large enough the p is in the circle centered at (0,n) with radius n? This really isn't conceptually hard. n can be as large as you like. Figure out the intersection of the circle with the vertical line through the point. Make it less than y.
Thread Closed
Thread Tools
Similar Threads for: Showing union of open sets is an open set?
Thread Forum Replies
Is the product of two open sets open? Differential Geometry 1
on open set on the line can be written as countable union of disjoint segments Calculus 10
finite intersection of open sets is open Calculus & Beyond Homework 3
Not so open minded open sets... Calculus 18
Do open sets stay open? Introductory Physics Homework 1
