cahnge in potential difference of moving electron
by Kastner86
Tags: electric force, electric potential, potential difference
Kastner86
Kastner86 is offline
#1
Sep26-09, 07:30 PM
P: 7
As an electron moves through a region of space, its speed increases from 2.2e^6 m/s to 6.0e^6 m/s. The electric force is the only force acting on the electron.
a) Did the electron move to a higher potential or a lower potential?
b)Across what potential difference did the electron travel?
2. Relevant equations
well for part b, i'm not even sure what to use.
K = 1/2mv^2
U=q x V
3. The attempt at a solution
Well i know part a), the electron moves to a higher potential.
I really don't know how to solve this since the distance or time is not given. And I may be confused as to the difference between potential difference and electric potential. I don't know where to start!
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
rl.bhat
rl.bhat is offline
#2
Sep26-09, 07:40 PM
HW Helper
P: 4,442
a) Electron moves in the apposite direction to the electric field. In the electric field the potential decreases along its direction. Then...?
b) The electron accelerates when it moves through lower potential to the higher potential. Hence its kinetic energy increases. Use the relevant equations and find the potential difference.
Kastner86
#3
Sep26-09, 08:09 PM
P: 7
Yes, i understand the electron is accelerating. obviously, its speed increases, so its kinetic energy also increases. I understand all these concepts.
I don't know which equations to use. That is where I'm stuck. All the equations I can think of using velocity have time or distance variable, which i can't use.
The only one I know is K = 1/2mv^2
So would I do [tex]\Delta[/tex]K = 1/2mv2^2 - 1/2mv1^2
and since [tex]\Delta[/tex]K = - [tex]\Delta[/tex]UE
I can then use [tex]\Delta[/tex]V = [tex]\Delta[/tex]U/e to get the potential difference???
Is [tex]\Delta[/tex]V potential difference or just potential or electric potential?? that is one area I am confused.
Thank you
rl.bhat
rl.bhat is offline
#4
Sep26-09, 08:11 PM
HW Helper
P: 4,442
Yes. ΔV = ΔU/e. No area is involved.
Kastner86
#5
Sep26-09, 09:59 PM
P: 7
This worked!
A big thanks to you. Sometimes just trying to explain the problem to someone else helps me solve it anyways.
Thanks!
Register to reply
Related Discussions
Potential Difference in and Electron/de Broglie Equation Introductory Physics Homework 2
Velocity of Electron through potential difference Introductory Physics Homework 3
Potential difference of an electron Introductory Physics Homework 4
electron speed/potential difference Introductory Physics Homework 0
Formula for electron accelerated across potential difference? Introductory Physics Homework 3
