Size and distance of different wavelengh photons?
  • Context: Graduate
  • Thread starter Thread starter crockman1
    Photons
The discussion revolves around the behavior of photons of different wavelengths, specifically regarding their speed, expansion, and interaction in various mediums. Participants explore theoretical aspects of light propagation, including the implications of Maxwell's equations and the nature of electromagnetic radiation.
  • Some participants question whether photons of different wavelengths travel at different speeds, despite the assertion that the speed of light is constant in a vacuum.
  • There is uncertainty about the term "expand," with some suggesting it may refer to the spreading of wave packets or group velocities.
  • One participant notes that in a vacuum, all electromagnetic radiation travels at the same speed, but in dispersive or lossy mediums, group velocities can vary with frequency.
  • Another participant emphasizes that photons have no physical size and do not expand or contract, describing them as discrete packets of energy.
  • Questions are raised about whether photons can affect each other, particularly in terms of repulsion when traveling parallel in a vacuum.
  • Participants inquire about the implications of light spreading over time, particularly in relation to laser sources and potential imperfections.
There is no consensus on the nature of photon behavior in relation to speed and expansion, with multiple competing views and ongoing questions about the implications of different mediums and the characteristics of photons.
Participants express confusion over terminology and concepts, particularly regarding the expansion of light and the implications of different mediums on photon behavior. The discussion includes references to theoretical models and assumptions that remain unresolved.
crockman1
a few questions for my own research (not too sure how to ask):
maxwells equations predicted that the speed of light should be the same watever the speed of the source. it follows from this that if a pulse of light is emitted at a particular time at a particular point in space then as time goes on it will spread out as a sphere of light whose size and position are independent of the source. after one millionth of a second the light will have spread out to form a sphere with a radius of 300 meters; after two millionths of a second, the radius will be 600 meters.
-stephen hawking
this leads me to ask
(a)
1.would a group of photons of different wavelengths/energy levels travel at different speeds in relation to photons of different wavelengths/energy levels?
2.would a group of photons of different wavelengths/energy levels expand at the same rate in relation to photons of different wavelengths/energy levels?
(b)
1.would a group of photons of different wavelengths/energy levels travel at different speeds in mediums in relation to photons of different wavelengths/energy levels?
2.would a group of photons of different wavelengths/energy levels expand at the same rates in mediums in relation to photons of different wavelengths/energy levels?
and what would be the size (radius), speed, and distance of two or more groups of photons of different energy levels, at one millisecond. if not known, two frames of reference in referring to time would be appriciated.
thank you
Science news on Phys.org
What do you mean by expand?
Note; i have restated the question to resolve this statement, p.s. thank you james this was a valuable statement.
The questions don't make a lot of sense to me. You seem to ask if different wavelengths/frequencies of light move at different speeds even after apparently correctly noting earlier that the speed of light is constant.
Next, this "expand" thing, I don't understand that either. You seem to understand that light expands in a spherical pattern, at the speed of light, though...
He could be talking about wave packets or the group velocities. The speed part would be the group velocity while the "expand" would be the spreading of a packet of information. Like the speed of a Gaussian pulse and then the spreading of a Gaussian pulse.
In any case, in vacuum, all photons move at the same speed. In a medium, it depends. If the medium is isotropic, loss-less, and non-dispersive, all photons will travel at the same speed. However, once the medium becomes lossy or dispersive, the group velocities will be come frequency dependent. This means that waves at different frequencies will travel at different speeds. It also means that if we sent in a Gaussian pulse (in the time domain, well frequency too since it so neatly Fourier transforms), then the pulse will widen as it travels through the medium because of dispersion. An example (ignore all the stuff about matter waves): http://www.physics.ucdavis.edu/Classes/NonclassicalPhysics/dispersion.html .
would for example a radio photon expand, and or travel at a different speed compared to a visible light photon? do all electromagnetic energy waves aka photons travel at the same speed and expand at the same rates reguardless of their frequency/ relative position in space?
In vacuum, all electromagnetic radiation travels at the same speed, regardless of wavelength.
How many oscillations (periods) are contained in a photon? This determines its "length".
in a medium too?
it would lead me to conclude from this statement that all electromagnetic radiation also expands at the same rate? if a visible photon has a 600m radius at one millisecond then an infrared photon or a gamma photon will also have a 600m radius at one millisecond?
another question, how far does a photon travel in one millisecond in space?
thank you all for your support
Whoa there. I already stated in my own post that the speed is constant across frequencies in a vacuum and any isotropic, dispersion-less, lossless medium. Once you add in effects like anisotropy, dispersion, and/or loss then the speed will be frequency dependent.
HOWEVER, photons have no physical size. They do not expand, contract, or anything of that kind from what we know. They are simply energy quanta, discrete packets of energy.
ohhh hawking must have been referring to a sphere emitting light in all directions then.
i have more questions:
do photons effect photons? in other words if two or more photons travel parallel to each other in a vacuum would they repel each other over time? lasers spread over time. would this be attributed to an imperfection in the angle of the source of the laser?
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 26 ·
