Poincaré, Ricci flow and Super String Theory
The discussion revolves around the relationship between the Poincaré conjecture, Ricci flow, and their implications in Super String Theory. Participants explore the mathematical concepts involved, particularly focusing on Calabi-Yau manifolds and their relevance to string theory.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants suggest that the proof of the Poincaré conjecture involves a modified Ricci flow, which may have connections to Super String Theory.
  • One participant notes a distinction between the dimensionality of a 3-manifold (related to the Poincaré conjecture) and a Calabi-Yau manifold, which is believed to be a 6-manifold, though they express uncertainty about this.
  • Another participant mentions that Perelman modified the Ricci flow equation by adding a term, which they believe is often used in string theories, but they remain uncertain about its applicability.
  • There is a reference to a Ricci-like analogue for renormalization group flow in quantum field theory models, with an unclear connection to string theory.
  • Participants discuss the dimensionality of Calabi-Yau spaces, with one asserting that they are defined as 2n-dimensional manifolds with SU(n) holonomy, suggesting that 6 dimensions are not the only possibility.
  • Several links to external resources are shared for further exploration of the topics discussed.
Participants express uncertainty regarding the connections between the discussed mathematical concepts and string theory. There is no consensus on the dimensionality of Calabi-Yau manifolds or the specific implications of the modified Ricci flow in string theory.
Participants acknowledge limitations in their understanding of string theory and the specifics of the mathematical concepts involved, indicating that further exploration is needed to clarify these relationships.
Readers interested in advanced mathematical concepts related to topology, geometry, and theoretical physics, particularly those exploring the intersections of these fields with string theory.
techwonder
I just read the latest Scientific American and they have an article about the proof of the Poincaré conjecture. Apparently the proof uses a modified (an extra element) Ricci flow and then the article says that the modification to the Ricci flow pops up in Super String Theory :confused: .
Does this relate to the Calabi-Yau manifolds and their possible transformations? How? Is it relevant to String Theory?
First off, I believe what is being described is a 3-manifold (3-sphere for the topologist) where I BELIEVE a Calabi-Yau manifold is a 6-manifold. (I may be mistaken).
Secondly, I believe Perelman, when modifying the Ricci flow equation, added a term to the equation. I do believe that this term is often used in string theories.
Still, it very well may be applicable to ST.
Paden Roder
Don't know squat about strings but i am curretly (slowly) reading the Perleman papers. There is a ricci like analogue for the renormalization "group" flow in some qft models...no idea if it comes up in string theory.
Mike Anderson has a nice page of notes on the proof and background...maybe that will help you:
http://www.math.sunysb.edu/%7Eanderson/papers.html
And this was the first overview of the papers from the period after the publication of the results:
http://www.math.lsa.umich.edu/research/ricciflow/overview102503.pdf
Also, i am not sure how they are viewed/used in string theory but i have always seen calabi Yau spaces defined as 2n dim manifolds with SU(n) holonomy.
So though 6 might be reasonable i see no compelling reason that it is the only dimension.
If you should find out the connection to strings please let us know.
  • · Replies 30 ·
12K
  • · Replies 73 ·
20K
