Register to reply
Proving a limit theorem of a sequence (square root)
by shoescreen
Tags: limit, proving, root, sequence, square, theorem
Share this thread:
shoescreen
#1
Sep29-09, 11:46 PM
P: 15
given the sequence {a_n} converges to A (non zero), show sqrt(a_n) = sqrt(A)
2. Relevant equations
3. The attempt at a solution
I've tried to expand |sqrt(a_n) - sqrt(A)| as |a_n - A|\|sqrt(a_n) + sqrt(A)| since that gives me the numerator to work with, but I can't figure out how to work with sqrt (a_n).
I'm trying a standard n* epsilon proof, that is finding an n* such that the above quantity is less than any positive real number epsilon.
Thanks for the help!
Phys.Org News Partner Science news on Phys.org
Climate change increases risk of crop slowdown in next 20 years
Researcher part of team studying ways to better predict intensity of hurricanes
New molecule puts scientists a step closer to understanding hydrogen storage
fmam3
#2
Sep30-09, 02:40 AM
P: 84
Suppose [tex]\lim a_n = A[/tex] and you want to show [tex]\lim \sqrt{a_n} = \sqrt{A}[/tex].
So, right now you need a bound for the denominator. Assuming that we are working with the reals (i.e. no complex numbers for this problem), then see that for the square root to be defined, we must have that [tex]a_n, A \geq 0[/tex]. Thus, that means we can simplify by writing [tex]| \sqrt{a_n} + \sqrt{A} | = \sqrt{a_n} + \sqrt{A} \geq \sqrt{A}[/tex] right?
That should be enough for you to finish the proof...
shoescreen
#3
Sep30-09, 11:10 AM
P: 15
hmmm, but the inequality is in the wrong direction. If want to compare |a_n - A|\|sqrt(a_n) + sqrt(A)| with a smaller sequence, I need something bigger in the denominator, and since root(A) <_ root (a_n) + root(A), I can't guarantee anything about the original sequence.
fmam3
#4
Sep30-09, 11:22 AM
P: 84
Note that WLOG, we can assume that [tex]A \ne 0[/tex] since if [tex]A = 0[/tex], then the result is trivial.
In fact, we can even further say that we can assume, WLOG that [tex]A > 0[/tex] (note the strict inequality). Then, if we have [tex]\sqrt{a_n} + \sqrt{A} > A [/tex], then does that not imply [tex]\frac{1}{\sqrt{a_n} + \sqrt{A}} < \frac{1}{\sqrt{A}}[/tex]? Can you finish the rest of the proof from here?
shoescreen
#5
Sep30-09, 11:42 AM
P: 15
I take back what i said before, the inequality is in the correct direction. It's frustrating, I had all of this before yet trashed it all because of that inequality sign. Ugh, guess i wasn't in math mode.
fmam3
#6
Sep30-09, 11:45 AM
P: 84
Quote Quote by shoescreen View Post
No prob :)
skoomafiend
#7
Feb3-12, 06:33 PM
P: 33
Quote Quote by fmam3 View Post
bumping an old post, but i am having trouble with a similar problem.
how would one continue from where he ended off?
thanks!
jbunniii
#8
Feb3-12, 06:41 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,171
Using the equality obtained in the excerpt you quoted, you would write
[tex]|\sqrt{a_n} - \sqrt{A}| = \frac{|a_n - A|}{|\sqrt{a_n} + \sqrt{A}|} < \frac{|a_n - A|}{\sqrt{A}}[/tex]
Now, can you make the numerator as small as you like by choosing a large enough n? If so, what can you conclude?
skoomafiend
#9
Feb3-12, 06:46 PM
P: 33
this is about where i'm getting stuck.
would be able to rephrase that question in any other way?
jbunniii
#10
Feb3-12, 06:52 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,171
You're trying to show that
[tex]\lim_{n \rightarrow \infty} \sqrt{a_n} = \sqrt{A}[/tex]
What does this statement mean? What is the definition of the limit of a sequence?
skoomafiend
#11
Feb3-12, 07:08 PM
P: 33
i am trying to show that for all ε > 0, there is an N such that for all n>=N i'll have,
[tex]|\sqrt{a_n} - \sqrt{A}| < ε [/tex]
i'm not understanding how to relate this (below) to my epsilon.
[tex]|\sqrt{a_n} - \sqrt{A}| < \frac{|a_n - A|}{\sqrt{A}}[/tex]
jbunniii
#12
Feb3-12, 07:34 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,171
You know that
[tex]\lim_{n \rightarrow \infty} a_n = A[/tex]
So given any [itex]\epsilon' > 0[/itex] (I intentionally put a ' on the [itex]\epsilon[/itex] to indicate that it's a different variable) there is an N such that
[tex]|a_n - A| < \epsilon'[/tex]
for all [itex]n \geq N[/itex].
Now think about what choice of [itex]\epsilon'[/itex] would be useful to get the result you require.
skoomafiend
#13
Feb3-12, 07:42 PM
P: 33
[tex]ε' = ε \sqrt{A} [/tex]
would this work?
thank you for all your help so far.
jbunniii
#14
Feb3-12, 07:51 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,171
Looks promising. Why don't you write out your argument in detail and we'll see if it works.
skoomafiend
#15
Feb3-12, 08:16 PM
P: 33
Since,
[tex]|a_n - A| < ε [/tex]
We have that for,
[tex] ε' > 0[/tex]
there exists N such that for all n>=N,
[tex]|\sqrt{a_n} - \sqrt{A}| < ε' [/tex]
so,
[tex]|\sqrt{a_n} - \sqrt{A}| < ... < \frac{|a_n - A|}{\sqrt{A}} < \frac {ε'}{\sqrt{A}} = ε [/tex]
where
[tex] ε' = ε\sqrt{A}[/tex]
I feel as though i'm missing some critical parts of the argument.
jbunniii
#16
Feb3-12, 08:24 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,171
You have the right idea, but you didn't arrange the proof quite correctly.
Try starting as follows:
Let [itex]\epsilon > 0[/itex]. We seek an [itex]N[/itex] such that whenver [itex]n \geq N[/itex], the following inequality is satisfied:
[tex]|\sqrt{a_n} - \sqrt{A}| < \epsilon[/tex]
We know that
Therefore, given [itex]\epsilon' > 0[/itex], ...
skoomafiend
#17
Feb3-12, 08:35 PM
P: 33
i'm definitely having trouble arranging the proof correctly.
the given ϵ′ is for [tex] | a_n - A| < ϵ' [/tex] ?
jbunniii
#18
Feb3-12, 08:50 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,171
Right. Given [itex]\epsilon' > 0[/itex], there exists an [itex]N'[/itex] such that
whenever [itex]n > N'[/itex].
I can choose [itex]\epsilon'[/itex] to be whatever I like, and there is guaranteed to be a corresponding [itex]N'[/itex] that makes the above inequality true. So I choose [itex]\epsilon' = \epsilon\sqrt{A}[/itex]...
Register to reply
Related Discussions
Is there a way of proving that all positive numbers have a real square root? Calculus & Beyond Homework 5
Prove that of sum square root of 2 and square root of 3 is not rational Calculus & Beyond Homework 15
Proove that the cubic root of 2 + the square root of 2 is irrational Calculus & Beyond Homework 4
Proving a given sequence is a delta sequence ~ Calculus & Beyond Homework 1
Proof of limit involving square root Introductory Physics Homework 6
