Can the BPX81 PhotoTransistor Circuit be Modified to Output 3.3V on IC1.1?
  • Thread starter Thread starter anita1984
    Circuit
The BPX81 PhotoTransistor circuit can be modified to output approximately 3.3V at IC1.1 by ensuring the BPX81 is nearly saturated, requiring at least 1mW/cm² illumination at 850nm. To achieve this, increase the resistance of R3 to several tens of K-ohms while keeping R2 at 500 ohms or less. Additionally, adding a catch diode from IC1 pin 1 to the 3.3V supply is recommended to prevent excessive input voltage. The optimal value for R3 will depend on the required switching speed of the circuit.
  • Understanding of BPX81 PhotoTransistor operation
  • Knowledge of circuit design principles
  • Familiarity with resistor values and their impact on circuit performance
  • Experience with diode placement in electronic circuits
  • Research the impact of illumination intensity on BPX81 performance
  • Learn about the effects of resistor values on switching speed in transistor circuits
  • Explore the use of catch diodes in protecting circuit components
  • Investigate alternative photoresistor options for achieving 3.3V output
Electronics engineers, hobbyists designing sensor circuits, and anyone looking to optimize photoresistor-based applications for specific voltage outputs.
anita1984
Hello forum i would like to ask about this circuit ( in attachment ) if it's possible to make it.I need to have on IC1.1 a 3.3V , or you have another good idea.
Thank you in advance,
Anita
Yes it's possible to get close to 3.3 volts at the input of IC1.1, but only just. You'll need to get the bpx81 almost to saturation which means you'll need at least 1mW/cm^2 illumination at 850nm and more if the wavelength is other than this optimum value.
You haven't exactly said but I assume that the problem you are having is that you're not getting enough voltage right. Well since the dark current is less than 1uA for T<50C you could probably increase the value of R3 up to several tens of K-ohm without any problems. Don't increase R2, leave it at 500 or less, but perhaps place a catch diode from IC1 pin 1 to the 3.3 volt supply to prevent getting too larger input voltage.
BTW. Exactly how high you should go with R3 largely depends on how fast the circuit needs to operate, a larger resistance will give a slower switch-off transient which may or may not be a problem.
Thank you a lot , till now i didn't try it , just i took your opinion about this , i will try it and i will let you know
Thank you,
Anita
  • · Replies 16 ·
  • · Replies 37 ·
  • · Replies 19 ·
  • · Replies 17 ·
