Thread Closed
Euler rotation confusion
Share Thread Thread Tools
Oct1-09, 04:32 AM   #1
Hello,
I am getting very confused.
I have a list of supernovae with galactic coordinates l (from 0->360) and b (from -180->180).
I am trying to write a program in Matlab that rotates the coordinates by 2 Euler angles. Firstly I change l and b into X,Y,Z i.e change from spherical to cartesian coordinate system.
Then I have the rotation matrix:
[X',Y',Z']=[X,Y,Z]* [cos(a) -sin(a) 0 ; -sin(a) cos(a) 0; 0 0 1]*[1 0 0 ; 0 cos(c) -sin(c) ; 0 sin(c) cos(c)]
I want to return a value (delta) which is a function of the SN properties at each rotation where a ranges from (0->360) in steps of 10 degrees and c ranges from (-90->90) in steps of 5 degrees.
The rotation matrix above only seems to work when the range is set as a from (-180->180) and c from (0->180). This means that I have to change l and b so that b ranges from (0->180) ie b=90-b, and l is in the range (-180->180) so l=l-180.
Then I need to plot the rotation values (that are colour coordinated according to the returned value delta) onto a plot that ranges a from (-180->180) and c that ranges from (-90->90). So I need to change c so that
c=90-c.
However, I think that I am doing something wrong somewhere.
I was wondering if anyone had done something similar to this before or if they can see what the problem is, OR alternatively if anyone knows the Euler rotation matrix that will have the range of a(0->360) and c(-90->90) as I have searched but can't find anything.
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Thread Closed
Thread Tools
Similar Threads for: Euler rotation confusion
Thread Forum Replies
Prove Euler Identity without using Euler Formula General Math 36
Translation of euler angles into rotation around arbitrary axis General Math 3
Euler rotation of objects with velocity vectors General Math 6
Results same w/ Euler, Improved Euler, & Runge-Kutta Differential Equations 14
vector rotation (possibly Euler angles) General Math 4
