Register to reply
Chemical equation for glucose osazone and limiting reactants
Share this thread:
IBY
#1
Oct1-09, 03:02 PM
P: 107
Okay, a while ago, I did a lab that had me get glucose osazone (C18-H22-N4-O4). Now, I am trying to calculate the theoretical mass of the osazone. The chemical equations goes as follows:
C6-H5-N2-H3*HCl + Na-C2-H3-O2*H2-O ------> C6-H5-N2-H3 + H-C2-H3-O2 + Na-Cl + 3(H2-O)
After that:
C6-H12-O6 + 3(C6-H5-N2-H3) --------> C18-H22-N4-O4 + C6-H5-N-H2 + N-H3 + 2(H2-O)
I found the limiting reactants in the first equation for Phenylhydrazine (C6-H5-N2-H3), but the thing is, in the second equation, 2 mols of phenylhydrazine gets used for osazone (C18-H22-N4-O4) and water, and the third mole decomposes into the ammonia (N-H3) and aniline (C6-H5-N-H2). So the part I am having trouble is, should I use the ration 2:1 from phenylhydrazine to osazone or keep the 3:1 ration in order to find the theoretical yield?
Phys.Org News Partner Science news on Phys.org
An interesting glimpse into how future state-of-the-art electronics might work
Tissue regeneration using anti-inflammatory nanomolecules
C2D2 fighting corrosion
chemisttree
#2
Oct2-09, 11:08 AM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,724
Quote Quote by IBY View Post
After that:
If instead of making the phenylhydrazine you used, you obtained it from a bottle... which ratio would you use?
Remember that the first reaction is essentially a neutralization reaction... the phenylhydrazine hydrochloride is free-based with sodium acetate. If I discover a way to do this that requires 20 moles of the the hydrochloride to my newly-discovered base (capable of neutralizing 20 moles of the hydrochloride!), will we all have to go back and rewrite every paper ever published that used sodium acetate for the job?
Register to reply
Related Discussions
Limiting and Excess Reactants in Redox Biology, Chemistry & Other Homework 1
Limiting reactants Biology, Chemistry & Other Homework 1
Determining Limiting Reactants Biology, Chemistry & Other Homework 1
Calculating masses of reactants&products in chemical reactions Introductory Physics Homework 0
Chemistry - Stoichiometry - Some limiting reactants Biology, Chemistry & Other Homework 3
