| Thread Closed |
Galilean Relativity |
Share Thread | Thread Tools |
| Oct2-09, 01:19 AM | #1 |
Galilean Relativity
An assembly line has a staple gun that rolls to the left at 1.0 m/s while parts to be stapled roll past it to the right at 3.0 m/s. The staple gun fires 10 staples per second. How far apart are the staples in the finished part? 2. Relevant equations r = r' + Vt 3. The attempt at a solution I set the frames of reference to be the staple gun (S) and the part to be stapled (S'), assuming that their origins coincide at t = 0. The coordinate system will be right = positive. I think that the object is also the part to be stapled. The velocity of the staple gun relative to the part will be -4.0m/s while the velocity of the part relative to the staple gun will be 4.0 m/s. (Do I need any formulas for that?) The position of the part is then given by: r = r' + Vt Since I assumed that the origins coincided at t = 0, then position is: r = Vt So then substituting the velocity and assuming 1 sec has elapsed: r = (4.0m/s)(1.0s) r = 4.0 m Since the staple gun fires 10 staples/sec, the distance between the staples should be 4.0 m/ 10 staples/sec, but that gives me 0.40 m*sec / staple. Am I doing something wrong? |
| Oct2-09, 05:11 PM | #2 |
Look at it this way. Assume you are sitting on the staple gun. You look around and you see that there are parts moving past you at 4.0 m/s which means that for every second that goes by, 4 meters worth of parts move past you. You know that 10 staples are fired in that one second that goes by. Can you figure out the distance between staples now?
| Oct2-09, 05:19 PM | #3 |
| Oct2-09, 05:36 PM | #4 |
Galilean Relativity
Yup.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Galilean Relativity
| Newton's bucket and Galilean relativity | Special & General Relativity | 7 | ||
| How Galilean relativity transformation produces inconsistency with classical physics | Introductory Physics Homework | 1 | ||
| Galilean Transforms-Relativity | Advanced Physics Homework | 5 | ||
| Galilean Relativity: I can't figure this out! | Introductory Physics Homework | 1 | ||
| Galilean Relativity and Tangential Acceleration | Introductory Physics Homework | 4 | ||
