Thread Closed
Point charge inside Dielectric Sphere embedded in Dielectric Slab
Share Thread Thread Tools
Oct4-09, 05:43 PM   #1
I've been working on this for a little while now (in CGS units), and am not really sure where I've gone wrong at in calculating the potential, so I've come here! Here is the problem:
What is the potential caused by placing a point charge Q at the center of a dielectric sphere ([tex]\epsilon[/tex]2), radius R, that is embedded inside some other infinite slab of dielectric ([tex]\epsilon[/tex]1)?
Here's what I've determined so far:
D(r) = Q/r2
E(r<R) = Q/[tex]\epsilon[/tex]2*r2
E(r>R) = Q/[tex]\epsilon[/tex]1*r2
So, letting P = (D-E)/4[tex]\pi[/tex] , I've found
[tex]\Phi[/tex](r<R) = Q/r + ([tex]\epsilon[/tex]2-1)*Q/(3*[tex]\epsilon[/tex]2*r)
[tex]\Phi[/tex](r>R) = Q/r + ([tex]\epsilon[/tex]1-1)*Q/(3*[tex]\epsilon[/tex]1*r)
My question is, shouldn't I have the option of allowing the potential to be continuous at the interface?? Have I left out some surface charge polarization or something?
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct5-09, 06:58 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by OsCiLL8 View Post
D(r) = Q/r2
Okay, so far so good...
Why are you calculating the polarization, and how did you go from the polarization to the potential?
"Option" is a poor choice of words, the potential must be continuous everywhere....the fact that yours is not should be a dead giveaway that you've done something wrong.
Oct5-09, 08:24 PM   #3
Calculating the polarization allows me to determine the contribution to the potential from the polarization surface charge density and polarization volume charge density.
I think your incorrect about the need for a continuous potential. The parallel E component and the perpendicular D componenent have to be continuous, implying that the potentials at the boundary be equal UP TO a constant. Setting the constant equal to zero makes the potential continuous, while setting the constant equal to a nonzero number implies that there is some work function required to go from one dielectric to the other.
Oct5-09, 08:48 PM   #4
Recognitions:
Okay, but you will also need to account for the potential due to the point charge, and you have made an error somewhere. If you post your calculations, I can point it out to you.
Alternatively, you can save yourself from the hassle of this method altogether by just using the definition of potential:
[tex]\textbf{E}=-\mathbf{\nabla}V\Longleftrightarrow V(\textbf{r})=\int_{\mathcal{O}}^{\textbf{r}}\textbf{E}\cdot d\mathbf{l}[/tex]
No, the potential must be continuous everywhere....What would the force be on a point charge located at a discontinuity in potential?
Oct5-09, 11:42 PM   #5
Homework Helper 2012
Recognitions:
The integral is a continuous function of the upper limit. Integrate E(r) from the place where the potential is chosen 0 (that is infinity) to r.
ehild
Thread Closed
Thread Tools
Similar Threads for: Point charge inside Dielectric Sphere embedded in Dielectric Slab
Thread Forum Replies
Electric Field inside uniformly charged dielectric sphere Advanced Physics Homework 8
Electric Field inside and outside of Dielectric sphere Introductory Physics Homework 0
Bound charge inside and outside a dielectric Advanced Physics Homework 1
Potential of a Dielectric sphere and an exterior point charge. Advanced Physics Homework 6
Dielectric Sphere in Field of a Point Charge Advanced Physics Homework 1
