| Thread Closed |
Series Wiring |
Share Thread | Thread Tools |
| Oct4-09, 07:44 PM | #1 |
Series Wiring
A 60W lamp is placed in series with a resistor and a 120V source. If the voltage across the lamp is 25V, what is the resitance R of the resistor? 2. Relevant equations I derived R= V2/P from ohm's law to solve this problem. 3. The attempt at a solution R= V2/P =(25V)2/60W =10.4 ohms Is this answer correct? Thank you in advance for your time and help. |
| Oct4-09, 07:48 PM | #2 |
Recognitions:
That's the resistance of the lamp.
Remember the current in the lamp an the resistor is the same, whats the voltage rop accross the resistor? |
| Oct4-09, 07:53 PM | #3 |
120v - 25v = 95v?
| Oct4-09, 08:25 PM | #4 |
Series Wiring
I guess I just don't understand what voltage to use and why.
| Oct4-09, 08:49 PM | #5 |
Recognitions:
You have 120V total, 25V accross the lamp and so (120-25) across the resistor
To work out the resistance you need the current through the resistor This is the same as the current through the lamp hint: Power = current * voltage difference |
| Oct4-09, 09:17 PM | #6 |
I=P/V
=60W/(120V-25V) =0.63 A R=V/I =95V/0.63A =151 ohms? |
| Oct4-09, 09:20 PM | #7 |
Recognitions:
sounds good
| Oct4-09, 09:22 PM | #8 |
Thank you so much for your help!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Series Wiring
| Wiring a Series and Parellel Switch for 12v/48v | Electrical Engineering | 3 | ||
| Series Wiring Problem | Introductory Physics Homework | 9 | ||
| correct series-or-parallel-or-off switch wiring? | Electrical Engineering | 6 | ||
| Series wiring problem | Introductory Physics Homework | 2 | ||
