Time Dilation Calculation: Astronaut vs. Earth Observer | Homework Solution
The discussion revolves around a time dilation problem involving an astronaut traveling at a significant fraction of the speed of light (0.90 c) and how this affects the measurement of pulse rates from both the astronaut's and an Earth observer's perspectives.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants attempt to calculate the time between heartbeats as perceived by both the astronaut and an Earth observer, raising questions about the correctness of their calculations and assumptions regarding time dilation.
There is ongoing exploration of the calculations, with some participants questioning the initial assumptions and results. Guidance is offered regarding the relationship between time dilation and the perceived rate of heartbeats, but no consensus has been reached on the final answers.
Participants are navigating through potential errors in their calculations and understanding of the time dilation formula, with some expressing uncertainty about their results and seeking confirmation.
wilson_chem90
An astronaut traveling at 0.90 c, with respect to Earth, measures his pulse and finds it to be 70 beats per minute.
a) Calculate the time required for one pulse to occur, as measured by the astronaut.
b) Calculate the time required for one pulse to occur, as measured by an Earth-based observer.
c) Calculate the astronauts pulse, as measured be an Earth-based observer.
t = to/{1 - v^2/c^2} ({ } = square root)
a) 70 beats per minute/60 seconds = 1.167 beats/per second
So that would mean it would take 1.167 seconds for one beat to occur.
b) t = to/{1 - v^2/c^2}
= 1.167 seconds {1 - (.90 c)^2/c^2}
= 1.167 seconds/(0.43589)
= 2.68 seconds
So it would take 2.68 seconds for once pulse to occur, measured by an Earth observer.
c) 2.68 seconds/beat x 60 seconds
= 160.8 beats/minute
It would be approx. 161 beats/minute if it was measured by an Earth observer.
I'm not sure if this is correct, can someone please confirm? Thank you
(a) Is not correct. If there are 70 beats in a minute and 60 seconds in a minute, then there are more beats than seconds in a minute. Therefore the time between beats is less than one second. Try again and reason it out correctly.
a) 60 seconds/ 70 beats per minute = 0.857 beats/second.
b)t = to/{1 - v^2/c^2}
= 0.857 seconds {1 - (.90 c)^2/c^2}
= 0.857 seconds/(0.43589)
= 0.373 seconds
So it would take 0.373 seconds for once pulse to occur, measured by an Earth observer.
c) 0.373 seconds x 60 seconds = 22.4 beats/minute
is that right?
As measured by the Earth observer, is the time between pulses longer or shorter than 0.857 s? Gamma is greater than one, so if "longer", you multiply by gamma; if "shorter" you divide by gamma.
Well it should be shorter
sorry it would be longer, not shorter
If it's shorter, then according to the Earth observer the astronaut's heart beats faster which means that the astronaut ages faster than the Earth observer. Does that sound right?
ohh i multiplied by accident. I was supposed to divide it. it would be 1.97 seconds/beat. Man i am just not cluing in today, sorry.
then c) would be 30.4 beats/minute. And no it wouldn't make sense at all if it was shorter.
is that correct?
I didn't do the numbers, but it looks about right.
oh okay, thanks for your help, i really appreciate it
  • · Replies 22 ·
  • · Replies 38 ·
