Radius of convergence of complex power series
The radius of convergence for the series ∑ n^-1.z^n, where n ranges from 1 to infinity, is determined using the ratio test. The series converges when |z| < 1 and diverges when |z| > 1. By applying the lemma regarding convergence in relation to points z_1 and z_2, it is established that the radius of convergence is indeed 1. The final conclusion is that the radius of convergence is a real number, specifically 1, not a variable.
  • Understanding of complex power series
  • Familiarity with the ratio test for convergence
  • Knowledge of convergence theorems in complex analysis
  • Basic concepts of limits and absolute values in mathematics
  • Study the application of the ratio test in more complex series
  • Explore convergence theorems in complex analysis
  • Learn about the implications of the radius of convergence in function theory
  • Investigate other tests for convergence of series, such as the root test
Students and educators in mathematics, particularly those focusing on complex analysis and series convergence, will benefit from this discussion.
Pyroadept
Find the radius of convergence of the series:
∑ n^-1.z^n
n=1
Use the following lemma:
If |z_1 - w| < |z_2 - w| and if ∑a_n.(z_2 - w)^n converges, then ∑a_n.(z_1 - w)^n also
n=1 n=1
converges.
The contrapositive is also true.
Hi, here's what I've done:
Let r be the radius of convergence. The series converges when |z-w| < r and diverges for |z-w|> r.
In this question, z = z, w = 0.
Use the ratio test for convergence:
lim |a_n+1 / a_n| = lim |zn / n+1 |
n->∞
= |z|
Thus the series converges when |z| < 1
So let |z - 0| = |z_2 - w|
Then, by the lemma, all |z_1 - 0| converges, where |z_1 - 0| < |z - 0|
and the converse is true for a diverging series.
Thus the radius of convergence = |z|
I think I've covered everything, but I don't think I've made very satisfactory use of the lemma. Can anyone please point me in the right direction?
Thanks for any help.
Your final answer appears to be "Thus the radius of convergence is |z|" which is meaningless. the radius of convergence is a real number, not a variable.
You had already said "Thus the series converges when |z| < 1
diverges when |z| > 1". What more do you need?
