What Are the Solutions to These Challenging Logic Puzzles?
  • Thread starter Thread starter Frohmeier
    Logic Series
The discussion revolves around three challenging logic puzzles that involve identifying patterns and making predictions based on visual sequences. Participants share their interpretations and proposed solutions while seeking clarification on the reasoning behind their choices.
  • Exploratory, Debate/contested, Conceptual clarification
  • Frohmeier presents three logic puzzles and requests assistance in solving them, noting the poor quality of the images.
  • Some participants suggest potential answers (B, E, D) and offer to provide explanations for their choices.
  • One participant questions the relevance of the number of corners in the puzzles and discusses the patterns observed in the squares.
  • Another participant describes a method for interpreting the first puzzle by analyzing the relationships between different types of squares.
  • There is a discussion about the movement of shapes in the second puzzle, with some suggesting that the trapezoid moves counterclockwise, while others express confusion about the warping indicated by arrows.
  • Participants explore the concept of "Sets" of squares, discussing the conditions under which they can be considered valid or invalid based on their types.
  • Some participants express differing views on the interpretation of the warping/stretching of shapes, leading to further debate about the reasoning behind the arrows in the second puzzle.
  • Frohmeier seeks clarification on the logic behind the arrows and expresses a preference for horizontal patterns in reasoning.
Participants do not reach a consensus on the solutions to the puzzles, with multiple competing interpretations and ongoing debates about the reasoning behind the proposed answers.
Some assumptions about the puzzles' structures and the relevance of specific visual elements remain unresolved, leading to varied interpretations among participants.
Frohmeier
Dear Forum Users,
I came across these three logic series' and as I was unable to resolve them, I thought about posting them here. Maybe you know the correct answers and care to explain? Sorry for the bad quality, but you should be able to recognise the patterns.
thanks,
Frohmeier
http://www.xoopit.com/s/20uda9vhnlgeju5hhwr1#pHPupPqboFWs6RJ2vEqCZAkJDgZi7oh4A
http://www.xoopit.com/s/20uda9vhnlgeju5hhwr1#qNy6XK8oJa2sKaTzNN20c3kJDgZi7oh4A
1. B
2. E
3. D
Explanations will follow if you're interested. Did you take these with your phone during an IQ test?
hello,
thank you very much for your response. yes I did take these pictures off a computer screen, so sorry for the bad quality.
If you don't mind I'd be very interested in the explanation,
thanks a lot,
Frohmeier
1) are the number of corners relevant?
http://ext.xoopit.com/2/pHPupPqboFWs6RJ2vEqCZAkJDgZi7oh4A/rmm.contents.raw?sig=d01856fa6a25aa6e11548ec16cc5191a&cd=a&sigKey=u5hhwr1
2) it's either d or e but which one makes sense?
http://ext.xoopit.com/2/qNy6XK8oJa2sKaTzNN20c3kJDgZi7oh4A/rmm.contents.raw?sig=fbbe1a4f0e4a9b61b8b9500ce574ae80&cd=a&sigKey=u5hhwr1
3) do the squares follow a certain pattern?
http://ext.xoopit.com/2/xrS1GnwV3KNu_3OtjfmKr4kJDgZi7oh4A/rmm.contents.raw?sig=16d7f2663c948a63b5c62b59308bb880&cd=a&sigKey=u5hhwr1
1 (the one with the boxes):
Look at the columns as equations.
An empty square plus a black square changes it to a highlighted square, while an empty square plus a highlighted one changes it to a black square. A highlighted square plus a black square forms an empty square. Any square plus a similar square retains its type.
2 (the one with a bunch of arrows in the answer choices):
By looking at the last three boxes you can tell that the trapezoid is going to move around the edge of the square and go counterclockwise. D or E could be potential answers then since both account for that movement. The arrows explain how the semicircle will be warped. Since it is acted on in more than two directions during the next three images, E--the answer with three arrows in it--accounts for this change.
3:
...I can't remember why I picked D, sorry. The only reason I could think of for it now was that its the only choice that has shapes similar to the sequence above in it and a star. I could just as easily say that the answer is E though and argue that the small star in boxes 2 and 4 adds a point to the big star.
thank you very much for your explanation,
I understood the one with the boxes, but I'm afraid I'm still confused by the arrow figure.
Do you mean that the arrow with the three arms points to the position of the rounded figure in the next three images?
thanks a lot,
Frohmeier
I meant the directionS that the semicircle would be streched.
ƒ(x) said:
An empty square plus a black square changes it to a highlighted square ... Any square plus a similar square retains its type.
Yep. The way I looked at it was that each column of individual squares will have either ALL the same types or ALL different types.
I dunno-- I'm not sure I follow this either. D & E are the "obvious" choices, since they have the trapezoid in the correct orientation (assuming it's sort of rotating counter-clockwise). But the warping part doesn't make sense to me. It would seem you're suggesting that it gets warped in 3 different ways, I assume you mean to imply that the left-most is the starting position from which it gets warped? To me, it's getting warped in 4 different ways from the left box to the middle box. And two ways from the middle to the middle-right, and two ways again from middle-right to far-right. Plus, I don't follow how an arrow would really indicate a warping action.
This one is actually A-- it was the only straightforward one to me. Count the line segments.
DaveE
Hello,
thank you very much for your input
ad 1: I was suspecting something like that, thanks for pointing it out. every square contains 13 line segments.
what do you mean by all the same or all different types? I'm not sure I follow
the arrows still don't make much sense to me,
thank you,
Frohmeier
Yup, you're correct. :rolleyes: I was too lazy to count the line segments haha. Think of it not so much as being warped in a specific manor, but that those are the directions that it's being streched in.
There are 3 different types of squares: Empty (E), Filled (F), and Darkish (D). Looking at (say) the lower-left squares in each of the boxes in the first column:
- The top box's lower-left square is Empty (E)
- The middle box's lower-left square is Filled (F)
- The bottom box's lower-left square is Darkish (D)
So each of the 9 square positions within a column of boxes has 3 values-- the top box, the middle box, and the lower box. I'll call that a "Set" of boxes. Each Set must either:
1) Contain all the same type of squares
2) Contain NO identical types of squares
Hence, the possible valid Sets (in order of Top, Middle, Bottom) are:
D,D,D
E,E,E
F,F,F
D,E,F
D,F,E
E,D,F
E,F,D
F,D,E
F,E,D
The invalid Sets would be:
D,D,E
D,D,F
D,E,D
D,F,D
E,D,D
F,D,D
E,E,D
E,E,F
E,D,E
E,F,E
D,E,E
F,E,E
F,F,D
F,F,E
F,D,F
F,E,F
D,F,F
E,F,F
DaveE
Yeah, I think I understand what you're implying-- I just disagree. If we assume the left-to-right progression, the direction of the warp/stretch is different in each of the last 3 boxes. If we assume the boxes from left-to-right are A, B, C, D, E, then:
From A -> C, the shape is stretched horizontally, goes from flat to concave on the left side, and has reduced convexity on the right side.
From C -> D, the shape shrinks vertically, the left side goes from concave to convex, and the right hand side goes from.
From D -> E, the shape is stretched vertically, possibly stretched horizontally, goes from convex to concave on the left side, and goes from flat to convex on the right side.
So, this makes things bizarre. If you put arrows in B, which imply the direction between A -> C, then why aren't there similar arrows for C -> D and D -> E? And if it's governing all the latter transitions, then why put it 2nd in the list, and how would you determine the order of operations? To put it simply, everything about this line of reasoning strikes me as wrong. I think there's probably something more sinister going on.
DaveE
Hello,
thank you very much for elaborating so patiently. I now understand what you meant and think it's a more intuitive approach. My problem is that I naturally look for horizontal patterns.
Still wonder if there is a logic explanation to the arrow problem?
thanks,
Frohmeier
For the arrow one I would say D was the answer.
Reason being that in each of the pictures the object that isn't the trapezoid has a 180 degree rotational symmetry through a horizontal axis that bisects the object (where that axis lays in the plane of the picture).
that makes more sense than my answer
Ahh, that's a decent answer! I was hoping for something a little more interesting, but that certainly works.
DaveE
  • · Replies 67 ·
17K
  • · Replies 33 ·
