Register to reply
Determine if series 3/n*sqrt(n) converges or diverges.
by NastyAccident
Tags: 3 or nsqrtn, converges, determine, diverges, series
Share this thread:
NastyAccident
#1
Oct8-09, 12:27 AM
P: 61
[tex]\sum^{\infty}_{n=1}\frac{3}{n^{1+\frac{1}{n}}}[/tex]
2. Relevant equations
Comparison Test
Limit Comparison Test
Test of Convergence (Just to show it doesn't immediately diverge)
3. The attempt at a solution
I sort of just would like to check to make sure I'm getting a proper [tex]b_{n}[/tex]
Manipulating the Series:
[tex]\sum^{\infty}_{n=1}\frac{3}{n^{\frac{n+1}{n}}}[/tex]
[tex]\sum^{\infty}_{n=1}\frac{3}{n\sqrt[n]{n}}[/tex]
Test of Convergence:
limit n->infinity [tex]\frac{3}{n^{\frac{n+1}{n}}}[/tex]
limit n->infinity [tex]\frac{3}{n^1}}[/tex]
limit ->infinity [tex]0[/tex]
The series MAY or MAY NOT be convergent.
Comparison Test
*Note* This series only contains positive terms*
From the looks of it, I'm going to GUESS that this series DIVERGES.
[tex]a_{n} = \frac{3}{n^{1+\frac{1}{n}}}, b_{n} = \frac{1}{n}[/tex]
[tex]a_{n} \geq b_{n}[/tex]
Since the series is [tex]\sum^{\infty}_{n=1} \frac{1}{n}[/tex], it is a p-series and it diverges because p [tex]\leq[/tex] 1.
By the Comparison Test, [tex]\sum^{\infty}_{n=1}\frac{3}{n\sqrt[n]{n}}[/tex] also diverges.
limit n->infinity [tex]\frac{\frac{3}{n^{\frac{n+1}{n}}}}{\frac{1}{n}}[/tex]
limit n->infinity [tex]\frac{3n}{n^{\frac{n+1}{n}}}}[/tex]
limit n->infinity [tex]\frac{3}{n^{\frac{1}{n}}}}[/tex]
limit n->infinity [tex]0[/tex]
By the Limit Comparison Test, [tex]\sum^{\infty}_{n=1}\frac{3}{n\sqrt[n]{n}}[/tex] is divergent since 0 > 0.
My questions:
Did I pick the right [tex]b_{n}[/tex]? If not, what did I do wrong in picking [tex]b_{n}[/tex]?
Any hints for picking the proper [tex]b_{n}[/tex]?
Was there a step that I missed or was unclear?
As always, any and all help is appreciated and will be greatly thanked! =) (I'm getting a 96% in Calc II thanks to the help I am receiving from this community in understanding concepts! [Nailed a 56/60 on a 20% exam!])
Sincerely,
NastyAccident.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Bohrok
#2
Oct8-09, 12:40 AM
P: 867
Your bn seems great for your tests.
[tex]\lim_{n\rightarrow\infty}\frac{3}{n^{\frac{n+1}{n}}}[/tex] does have a limit; look at the denominator n1 + 1/n as n→∞
Mark44
#3
Oct8-09, 01:04 AM
Mentor
P: 21,312
For your comparison test, with an being the terms in your series, and bn being the terms in the harmonic series, you said that an >= bn. That very well may be true, but you would need to establish this inequality instead of merely stating it.
For your work using the limit comparison test, you concluded that
[tex]\lim_{n \rightarrow \infty}\frac{a_n}{b_n}~=~0[/tex]
(with an and bn still as defined above), which is not true.
In your work you show [tex]\frac{\frac{3}{n^{1 + 1/n}}}{\frac{1}{n}}~=~\frac{3}{n^{1/n}}[/tex]
which is correct, but in evaluating the denominator limit you got an incorrect value. Here's how that goes, looking just at the limit of the denominator:
[tex]Let~y~=~n^{1/n}[/tex]
[tex]Then~ln~y~= ln (n^{1/n})~=~1/n*ln~n~=~\frac{ln~n}{n}[/tex]
Taking the limit of both sides, we have
[tex]\lim_{n \rightarrow \infty}ln~y~=~\lim_{n \rightarrow \infty}\frac{ln~n}{n}[/tex]
[tex]=~\lim_{n \rightarrow \infty}\frac{1/n}{1}~=~0[/tex]
The last limit was evaluated using L'Hopital's Rule.
Since lim ln y = ln lim y = 0, this means that lim y = 1.
The upshot of all this is that lim 3/(n1/n) = 3, and not 0 as you wrote.
This shows that your series diverges, which is in agreement with your instincts.
NastyAccident
#4
Oct8-09, 08:49 PM
P: 61
Quote Quote by Mark44 View Post
Attempt to satisfy #1 (I'm assuming I do not have to do mathematical induction):
[tex]\frac{3}{n^{1+\frac{1}{n}}}\geq\frac{1}{n}[/tex]
[tex]\frac{3}{1^{1+\frac{1}{1}}}\geq\frac{1}{1}[/tex]
[tex]\frac{3}{2^{1+\frac{1}{2}}}\geq\frac{1}{2}[/tex]
Attempt to satisfy #2 (Please note, I lacked knowledge on Le'Hospital's rule prior to this year since my AB teacher did not teach it.):
Indeterminate form
shows that this is infinity to the 0 power case....
Transformation is:
Which matches what you did.... So =) Thanks for directing me to pull out the Indeterminate forms... I'll be studying them this weekend!
Sincerely,
NastyAccident
Register to reply
Related Discussions
Technical question regarding showing sqrt(n+1) - sqrt(n) converges to 0 Calculus & Beyond Homework 2
Limit diverges or converges Calculus & Beyond Homework 3
Converges absolutely, conditionally, or diverges Calculus & Beyond Homework 6
Series converges or diverges? Calculus & Beyond Homework 5
Determine whether the series converges Calculus & Beyond Homework 18
