Solving Summations with Modified Exponents
  • Context: Undergrad
  • Thread starter Thread starter Buddy711
    Summation
The discussion revolves around solving a summation problem involving modified exponents in a series. Participants explore methods to manipulate the series to achieve a desired form for summation, focusing on the mathematical techniques involved.
  • One participant presents a summation problem and expresses uncertainty about the formulas for summation of sequences.
  • Another participant suggests using the formula for the sum of a geometric series and differentiating it to find a related summation involving n.
  • A later reply points out the difference in the exponent (n-2 vs n-1) and emphasizes the need to adjust the series accordingly.
  • One participant acknowledges the suggestion and expresses a realization about the relationship between the exponents, indicating a potential path forward.
Participants do not reach a consensus on the solution, as the discussion remains focused on manipulating the series rather than arriving at a final answer.
There are unresolved issues regarding the manipulation of the series and the implications of changing the exponent, which may affect the summation result.
Buddy711
Hi everyone.
I hardly remember the fomulas of summation of sequence.
I got this problem.
[tex]{\frac{1}{8}}\sum^{\infty}_{n=2}n({\frac{3}{4}})^{n-2}[/tex]
The result is 2.5.
How can I solve this problem?
Thanks all. :)
Assuming |r| < 1 then
[tex]\sum_{n=0}^{\infty} r^n = \frac{1}{1-r}[/tex]
Differentiation both sides with respect to r gives:
[tex]\sum_{n=1}^{\infty} n \cdot r^{n-1} = \frac{1}{(1-r)^2}[/tex]
This should give you a push in the right direction.
(Warning: Be careful of your initial index.)
--Elucidus
You suggested me very good approach.
However, the problem still remains,,,
my equation is n vs (n-2), not n vs (n-1)
Thanks!
Raising it to the power of n-2 instead of n-1 is just dividing it by 3/4. You should be able to find a way to modify your series so that you have an n-1 in the exponent
You are absolutely right.
I was so stupid.
Thank you ;-)
