| Thread Closed |
Faraday's Law Is False! |
Share Thread |
| Mar3-10, 05:17 PM | #86 |
Faraday's Law Is False!Regarding FL, you firmly state that FL is valid for xfmr induction, i.e. time-varying flux. You state that it must be true always, and that with static flux, no inducton can take place. Yet a Hall effect current sensor produces induction with static flux. A xfmr cannot do this. So there is something else going on here. In a HG, the flux & induced current/voltage are static. FL relates the induced I/V to the change rate of the flux. Motional emf/mmf is due to the flux spatially varying so that the actual flux encountered by the circuit is time changing. Moving through a spatial flux change results in a time varying flux in the circuit reference frame. Thus if phi varies with spatial position r, and velocity u is dr/dt, then d(phi)/dr * dr/dt = d(phi)/dt, by the chain rule. So FL covers this aspect of induction. Moving through a flux that is static wrt time, but varying wrt position, is equivalent to sitting still with the flux time-varying. The HG is best explained by Lorentz force & relativity. Remember in a HG, we set the electrons in motion by expending energy in rotating the disk. Then the magnetic field acts upon the moving electrons per Lorentz. Charges are separated and a static E field is formed, with a dc voltage & current. E fields induced per FL are solenoidal. No sources or sinks exist, they have rotation, & are non-conservative. E = -dA/dt, where A = magnetic vector potential, B = curl A. E fields in the HG have sources and sinks due to charge separation, have no rotation, are conservative, and E = -grad V, where V is scalar electric potential. Clearly the E fields in the HG are markedly different than those in FL type generators. This is a different mechanism, likely related via relativity. Optical is energy. Have you seen what happens when sunlight is focused through a magnifying glass into a point and focused on a piece of paper? No energy?! Indeed! That's all for now. Let's review the paper and discuss further later. BR. Claude |
| Mar3-10, 08:14 PM | #87 |
One more thing should be mentioned. According to Maxwell's published law of Faraday (1873):
curl E = -dB/dt. What is he saying here? If the flux time derivative is zero, is E zero? Of course not. He's saying that the curl of E is zero. In the HG case, that is exactly what is measured. The Lorentz force due to electron motion relative to the static field acts radially so that plus & minus charges are separated, center & periphery, resulting in an E field radially. But this E field is due to charged particles. It has no curl. Maxwell/Faraday predicts just that. A non-rotational E field. The HG perfectly affirms and vindicates FL per Maxwell. Transformers & motors/generators OTOH, per Faraday induction, exhibit E fields with curl. So there is no paradox after all. Maxwell & Faraday got it right all along. I'm glad that's settled. Good day to all and feedback is welcome. Claude |
| Mar4-10, 12:34 PM | #88 |
I'm not sure if this is helps or not, but for what it's worth, in Daniel Fleish's "A student's guide to Maxwell's Equations" he distinguishes b/w the convenient Flux Rule, which is a handy formula, and a modified version of Faraday's Law, which is more subtle and rigorous, and, he believes, correct. I'll post the quote and formula if I can find it.
Regarding Feynmann's quote, I found the likely source in the Wikedia article Faraday's Paradox in the section Inapplicability of Faraday's Law Just after the Feynmann quote, the argument is made that once SR is taken into account, Faraday's law holds true. I don't know enough to pass any judgment, but at first pass it seems Feynmann is arguing more against the universality of the handy flux rule, but not necessary the fully expressed Faraday's law w/ perhaps SR taken into account. |
| Mar4-10, 06:54 PM | #89 |
Claude,
I did not say that with static flux, no induction could take place; I said that that is what FL implies. That is one reason why FL is false. Flux change due to motion is not physically (in the sense of physics) the same as time-varying flux without motion. That is the whole crux of the matter. The two have completely different physical results. The former leads to motional EMF and the latter results in transformer EMF in accordance with one of Maxwell's four classic laws. When you say that E fields induced per FL are solenoidal, you are mistaken. That is only true when there is an intrinsic change in the flux. It is not true when there is motional EMF. FL does not distinguish between the two, which is why it is false. Light is certainly energy. But energy transfer in an optocoupler, though necessary, is incidental to the transfer of a signal, which is the purpose of an optocoupler. Mike |
| Mar4-10, 07:10 PM | #90 |
diagopod,
The flux rule discussed by Feynman is exactly the same as what we are referring to as Faraday's Law in this thread. Relativity is really irrelevant, as it came along long after FL. FL is very simple and simply false, as I have demonstrated earlier in this thread. Mike |
| Mar5-10, 04:48 AM | #91 |
The truth is (and I sure hope you are not spreading your errors among the young) that science is done with the MIND! It all starts between the ears. I don't care how much money you spend, if you can't think it won't be science! And the truth is that Faraday's law as typically stated IS wrong (but interestingly NOT wrong according to how Faraday stated it!). Does anyone here understand how the rocking plates work? Why doesn't the changing flux give a voltage? Here, I'll explain it to you guys. Here's the equivalent idea and one more case where Faraday's supposed law is invalid. Imagine a large rectangular loop of wire with a meter in the circuit. Imagine a magnet putting a local flux through an area in the end of the loop near the meter. Imagine a wire and a switch connecting the sides of this loop that when thrown cuts it into two loops. Now move the magnet to the other end of the large loop (nothing happens as flux enclosed in loop has not changed). Now close the shorting switch. Remove the magnet. Open the switch. Voila. The flux has gone from max to zero and the meter does not move! Faraday is invalid! But the error that makes Faraday's law misinterpreted is that one assumes that a changing magnetic field (flux) causes an induced E field. (An E field in a conductor creates a current) Sorry, the equation Curl E = -db/dt or as often stated EMF = -dB/dt are TRUE relations but they are not CAUSAL relations! You need to understand what that means. It means that while the value of an induced E and a magnetic field are RELATED they DO NOT cause each other. Hence a voltage is NOT repeat NOT created by a changing magnetic field! If one examines the causality of Maxwell's equations one finds that BOTH magnetic and electric fields are BOTH created by ONLY by charges and their motions (currents). Hence an induced EMF is created by a current somewhere as it's source. And that current ALSO creates a magnetic field. BOTH are related (as they come from the same source) by Faraday's law in many cases, but the changing magnetic field is NOT causing the EMF! Indeed even in the case of moving magnets one can show that the EMF is created by the moving atomic CURRENTS that create the fields of the permanent magnets. Hence, as Feynman clearly states, Faraday's law is NOT valid for all cases. In cases for example where the configuration of our setup is changing (our switching example) it simply does not work. It didn't work in Faraday's time either as proved by the generator bearing his name! Which is why Faraday NEVER said that a changing magnetic field induces an EMF. He said that a changing CURRENT can induce another current nearby! Obviously even though Faraday didn't have much of a clue, he still knew more about the subject than all the "modern" physicists with their PhDs, money, accelerators and scanning microscopes! OK? |
| Mar5-10, 02:36 PM | #92 |
bjacoby,
Well, at last a posting that supports me! Believe it or not, yours is the first since I initiated this thread. Thanks. Mike |
| Mar5-10, 04:34 PM | #93 |
Mentor
If you guys do not stop snipping at each other and do not go back to strictly discussing on-topic subjects, this thread will be closed!
Zz. |
| Mar5-10, 04:43 PM | #94 |
| Mar5-10, 04:53 PM | #95 |
Mentor
Zz. |
| Mar5-10, 06:20 PM | #96 |
So, my misunderstanding is based on the fact that you 'can' find the relative velocities, and then measure forces. How is there a symmetry here? We can grab a physical thing that has charge and test it with another charged thing, and this force is observed when there is no motion. How do you account for the 'static' electric field? If you want to explian it with symmetry, it seems that the E fields would have to be due to some sort of moving magnetic charges, but since the E field is localized (not moving) and falls off as 1/r^2 (not a dipole field or something), then I don't see it. Thanks! |
| Mar6-10, 01:18 AM | #97 |
Well what does succeed? First let me note again that the proper statement of Faraday's law is that a current creates another current. There is no magnetic field involved at all! This is proper causality! So let us start with the magnet. How does it work? Well, it is believed that electrons circulating around the atoms create a current loop that creates a permanent magnetic field. One can show that for homogeneous materials this is equivalent to a larger current circulating about the outside of the magnet. cylindrical magnets and thin solenoids make nearly identical fields. Now near that circulating current we have a rotating disk. So lets put the disk in one frame and the magnet in another. For drill lets rotate the magnet rather than the disk. So now we wish to calculate the electric field induced about the magnet. Well, if the magnet is still, there is none as the magnet material is electrically neutral. But what happens when the magnet rotates? Here is the crux. Remember that only CHARGE and CURRENTS can be sources of E fields! Hence the magnetic field does not matter! So if one examines a neutral current moving with constant velocity in the direction it is flowing one finds that two E fields are induced One is an ordinary electrostatic E field due to the motion and the other is an Induced electrokinetic E field also due to the motion. It can be shown that in the case of a current loop rotating about its axis so the current has a constant velocity in the direction it is flowing an E field is induced equal to -V x B. But make no mistake here. This field is NOT caused by B! Just it's VALUE can be calculated using B! The induction is from a current loop DIRECTLY to the E field producing the generator potential! Of course this is EXACTLY how Faraday stated his observations: "When an electric current is passed through one of two parallel wires it causes at first a current in the same direction through the other, but this current does not last a moment notwithstanding the inducting current (from a voltaic battery) is continued..." Here we have the equivalent currents in the magnet creating a current (E field) in the surrounding space by virtue of their relative motion. If the magnet and disk are in the same frame, then there is no E field observed and no induced potential. Hence Faraday's law as stated by Faraday is correct, but the traditional versions that ascribe the creation of an E field as being created by a B field are simply incorrect. The magnetic field is just something that is ALSO there. It has the same current source as the induction and therefore is RELATED to it, but most certainly does not CAUSE the generator action. It is the hard fact that ALL induced E fields are created by charges and currents and NOT by magnetic fields that means that Faraday's Law as usually interpreted is false. |
| Mar6-10, 03:42 AM | #98 |
Mentor
That is completely wrong. An electric field can be created by a changing magnetic field.
| Mar6-10, 04:02 AM | #99 |
Disconnecting the meter temporarily, while you remove the magnet will prove your point as well? |
| Mar6-10, 11:12 AM | #100 |
The very title of this thread is an affront to the scientific method and seeks to do nothing but mislead the novice. Note that it is important to use a proper form of Faraday's Law based on the situation. This can be done with the Tensor formulation of Maxwell's equations, or a proper general vector form of Faraday's law as follows: [tex]\int (E+v \times B) \cdot dl=-\int {{dB}\over{dt}}\cdot ds[/tex] |
| Mar6-10, 01:31 PM | #101 |
bjacoby,
You said that with the Faraday disk it is hard to make a case that the [free] electrons are dragged around with the disk as it turns. It is not hard at all, actually. In a typical current-carrying wire, the free electrons composing the drift current travel at a net speed of about a micron a second. If they did not travel around with the disk, they would constitute a tremendous current that would vaporized the disk with instantaneous heating. Mike |
| Mar6-10, 01:43 PM | #102 |
elect_eng,
You state that the operation of the Faraday disk is not based on Faraday's Law. That means that the basis of the operation of the Faraday disk is motional EMF and that motional EMF and Faraday's Law are independent. If they are independent, Faraday's Law cannot include motional EMF, which is what I have been maintaining all along. The equation you posted is exactly equivalent to what we have been referring to as Faraday's Law in this thread and is certainly false, as I have conclusively demonstrated throughout this thread. Mike |
| Thread Closed |
Similar Threads for: Faraday's Law Is False!
| If GUT are false, are string-based unification also false? | Beyond the Standard Model | 1 | ||
| true or false/correct if statement is false help | Biology, Chemistry & Other Homework | 2 | ||
| I can't figure out if this statement is true or false, i said false | Calculus & Beyond Homework | 4 | ||
| Faraday's Law Help? | Introductory Physics Homework | 4 | ||
| Faraday's Law | Classical Physics | 5 | ||
