Thread Closed
Work-Energy Theorum: Spring potential energy vs Kinetic Energy
Share Thread
Oct10-09, 07:22 PM   #1
A 1350-kg car rolling on a horizontal surface has a speed v = 40 km/h when it strikes a horizontal coiled spring and is brought to rest in a distance of 2.5 m. What is the spring constant of the spring? Ignore Friction and assume spring is mass-less.
2. Relevant equations
[tex] W = \Delta E[/tex]
[tex] E_{pspring} = \frac{1}{2}(kx^2) [/tex]
[tex] E_k = \frac{1}{2}(mv^2) [/tex]
3. The attempt at a solution
First right off the bat, i converted 40 km/h to its m/s equivalent of aprox. 11.11 m/s
i state the law of conservation of energy: Energy before = Energy after
Therefore:
[tex]
E_k = E_{pspring}
\frac{1}{2}(mv^2) = \frac{1}{2}(kx^2)
[/tex]
then i isolate k
[tex] k = \frac{-mv^2}{x^2} [/tex]
now heres the issue, is x negative? because the displacement is against the direction of motion?
and 2.5m = x, (-2.5)^2 gives me a answer of 4266 Nm
but -(2.5)^2 is entirely different.. This has been a long lasting math issue for me.
And what if x is positive?
i know k MUST be positive right?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct10-09, 08:21 PM   #2
Recognitions:
Homework Helper Homework Help
(2.5)^2 is correct. There is no negative energy in the nature.
Oct10-09, 08:25 PM   #3
Recognitions:
There is no minus sign in mv^2 = kx^2
or in k = mv^2/x^2. No way you can get k negative!
The minus sign in F = -kx is supposed to help keep track of the fact that the force of the spring is opposite to the direction of stretch but it does seem to have a habit of getting in the way. k is ALWAYS positive.
Oct11-09, 08:41 AM   #4
Thanks, the negative sign on mv^2 was an algebra error... Thanks for the clarification guys!
May18-10, 09:56 AM   #5
Your attempt is correct but you missed somethingthat for a spring if you take natural length as the datum, the force on change in length is given as:
[tex] \vec{F}= -k \vec{x} [/tex]
and hence work done by a spring against external forces
[tex] W_{s}=\int\vec{F}\vec{.dx} [/tex]
over the required limits
in our case the answer is
[tex]W_{s}=-\frac{kx^{2}}{2}[/tex]
as
[tex]W_{s}=\Delta E[/tex]
[tex]\Delta E=-\frac{mv^{2}}{2}[/tex]
the change part was where you lost it all...the KE FELL TO ZERO. HENCE A NEGATIVE CHANGE.
Thread Closed
Similar discussions for: Work-Energy Theorum: Spring potential energy vs Kinetic Energy
Thread Forum Replies
Work and Potential/Kinetic Energy (spring problem) Introductory Physics Homework 2
Kinetic Energy, Potential Energy, Work Introductory Physics Homework 3
Work-Kinetic Energy Theorum Problem Introductory Physics Homework 3
HELP! ~ Mechanical Energy vs Potential Energy & Kinetic Energy Introductory Physics Homework 4
[SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy Introductory Physics Homework 3
