Expected Value (probability problem)
The discussion revolves around calculating the expected value of winnings in a sweepstakes based on given prize amounts and their respective probabilities. The participants are examining the application of the expected value formula in the context of probability theory.
  • Mathematical reasoning, Assumption checking
  • Participants are attempting to apply the expected value formula but express uncertainty about their calculations. They question the accuracy of the provided probabilities and prize amounts, noting discrepancies in the expected probabilities of winning different prizes.
Some participants have shared their calculations and agree on the results, while others are exploring the possibility of errors in the problem setup. A potential typo in the prize values has been identified, which may affect the calculations.
There is mention of a possible typo regarding the prize amount of $800,000, which may actually be $800, leading to confusion in the calculations. Participants are encouraged to verify the accuracy of the prize values as presented in the problem.
snoggerT
Prizes and the chances of winning in a sweepstakes are given in the table below.
Prize: Chances
$25,000,000: 1 chance in 400,000,000
$250,000: 1 chance in 150,000,000
$75,000: 1 chance in 50,000,000
$10,000: 1 chance in 4,000,000
$800,000: 1 chance in 500,000
A watch valued at $70: 1 chance in 8,000
Find the expected value (in dollars) of the amount won by one entry.
E(X) = X_1*P(X_1)+X_2*P(X_2)+...
I used the formula listed above and do not get the right answer. I'm really unsure as to why that doesn't work. I use the dollar values for my X and then the chance as my P(X). Can someone explain to me where my fault is in working this problem?
Prize: Chances
Please show us your work. It might be that you made an arithmetic mistake that is causing your answer to be incorrect.
As a side note, it's odd that the probability of winning $25M is relatively high, compared to the probability of winning a prize that is only 1% of that.
Also, you show 1 chance in 4 million of winning $10,000, for 1 chance in 1/2 million of winning $800,000. Are you sure that you have written all the prizes and their probabilities exactly as presented in the problem?
- I copied the values straight from the webwork homework. I do find it very odd that the numbers go from $10,000 @ 1/4,000,000 chance to $800,000 @ 1/500,000 chance. But here is how I worked the problem:
E(X) = (25,000,000*(1/400,000,000))+(250,000*(1/150,000,000))+(75,000*(1/50,000,000))+(10,000*(1/4,000,000))+(800,000*(1/500,000))+(70*(1/8,000)) = 1.67691666666667
I don't see anything wrong with it. I get the same answer.
- yeah, I'm at a loss. Maybe the numbers are showing up wrong in relation to the actual answer.
Alright, I figured it out. The $800,000 value is supposed to be $800. So I suppose my professor made a typo when setting the problem up.
If you get the "right" answer when you replace $800K by $800, that probably is what happened.
  • · Replies 31 ·
  • · Replies 20 ·
