Thread Closed
Banked curve min/max velocities
Share Thread Thread Tools
Oct11-09, 09:42 PM   #1
A curve of radius 15 m is banked so that a 930 kg car traveling at 48.0 km/h can round it even if the road is so icy that the coefficient of static friction is approximately zero. You are commissioned to tell the local police the range of speeds at which a car can travel around this curve without skidding. Neglect the effects of air drag and rolling friction. If the coefficient of static friction between the road and the tires is 0.300, what is the range of speeds you tell them?
2. Relevant equations
Nsinø = (mv^2)/r
N cos ø = mg
3. The attempt at a solution
Combining these and simplifying produces rg tan ø = v^2
Solving for theta I get 50.38
I then return to the equations, but instead add friction force
mgtanø = (mv^2)/r + μ(mg/cosø) and mgtanø = (mv^2)/r - μ(mg/cosø)
solving these for velocity, but this produces the wrong answer (I get 37.50 km/h and 56.58 km/h)
Thanks in advance for the help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct11-09, 11:15 PM   #2
Recognitions:
Homework Helper Homework Help
Welcome to PF, ndoc.
It seems to me the situation is more complicated for the case with friction. I'm thinking of mg down and the CENTRIFUGAL force horizontal to my right. So the normal force is mg*cos(A) + mv^2/r*sin(A). Certainly it makes sense that as the car goes faster, it gets pressed harder against the banked road, increasing friction.
Thread Closed
Tags
bank, curve, maximum, minimum, velocity
Thread Tools
Similar Threads for: Banked curve min/max velocities
Thread Forum Replies
Banked Frictionless Curve, and Flat Curve with Friction Introductory Physics Homework 1
car on a banked curve Introductory Physics Homework 1
banked curve Introductory Physics Homework 10
Banked curve Introductory Physics Homework 4
Banked Curve Introductory Physics Homework 8
