Can Gravity Be Cancelled? Theories and Research on the Effects of Gravity
  • Context: Graduate
  • Thread starter Thread starter oozie1
    Effects Gravity
The discussion revolves around the nature of gravity, including its presence, effects, and theoretical possibilities of canceling it. Participants explore various questions related to gravity's influence on objects, light, and time, as well as referencing research by Dr. Abd Salam regarding gravity cancellation.
  • Some participants assert that gravity is present everywhere, with gravitational fields extending infinitely, while others suggest that gravity's effects can be canceled out in specific scenarios, such as at the first Lagrange point between two equal mass bodies.
  • There is uncertainty regarding whether gravity moves faster than light, with some participants believing it does not, while others suggest that the propagation speed of gravitational effects is still a topic of debate.
  • Participants discuss the interaction between gravity and light, noting that light follows curved paths in gravitational fields, which leads to phenomena such as black holes appearing invisible.
  • Some participants propose that if there were no gravity, there would be no time, while others challenge this notion, emphasizing that gravity warps time rather than creates it.
  • Dr. Abd Salam's research is mentioned, with claims that he has partially succeeded in canceling gravity, particularly in relation to the construction of the Great Pyramid of Giza.
Participants express a mix of agreement and disagreement on various points, particularly regarding the nature of gravity, its effects, and the implications of Dr. Abd Salam's research. No consensus is reached on the possibility of canceling gravity or the relationship between gravity and time.
Some claims about gravity's effects and the nature of spacetime are based on interpretations of general relativity, which may not be universally accepted or understood among participants. The discussion includes speculative ideas that are not fully substantiated.
oozie1
I have got many questions:
1. Is the anywhere that gravity is not present?
2. If there was two planets of equal size and mass, they were a distance apart. And an object was equal distance from both would the influence of gravity cancel each other out therefore making this an area gravityless??
3. Does gravity move faster than light?
4. Why does gravity effect a path of light i.e. why are black holes invisible does light really get pulled towards it?
Any answers or theories are welcome.:smile:
1. No. In the Newtonian picture, gravitational fields extend to infinity. The strength of the gravitational force falls off as the square of the distance, but never reaches zero until you're at infinite distance. In the post-Newtonian (general relativistic) picture, gravitational fields are just artifacts of the curvature of space. Every point in space always has a curvature (even if that curvature is zero), thus "gravity exists" everywhere.
2. The point halfway between two equally-massive bodies is called the "first Lagrange" point, called L1. It is an unstable place to be, very much like sitting on the apex of a barn roof. The gravitational forces due to the two bodies cancel at L1 -- but, of course, the rest of the universe may impose additional forces.
3. No one is quite entirely sure yet. Relativists would like to believe that no information can propagate faster than the speed of light, and thus that gravitational influences propagate at or less than the speed of light. Some experiments have been performed, but their validity has been questioned. If gravitation actually does propagate faster than light, it can lead to some rather weird conclusions.
4. In general relativity, gravitation is the result of bodies moving through the straightest possible lines in curved space. Light is not immune to the curvature of space, and follows those curves just like anything else.
- Warren
I see thanks for answering my quams!
----------------------------oozie--------------------------
3. It is generally believed that gravitation moves at the speed of light.
Bonjour, IMHO,
1. Is there anywhere that gravity is not present?
If somewhere you don't have gravity, you wouldn't have time.
Gravitational forces shall be equal in intensity and opposite in direction, then you'll be "weightless". But if you point your arms in direction of each planet, they will be oppositively attracted. You still have two gravitational fields but in opposite direction cancelling out effects but not removing the cause, the fields.
I would said that the "speed of light" shall be labelled "maximum speed of event". You wouldn't be able to observe an event where the gravitational force's effect propagates faster than c. Else you shall modify one (or both) of the metrics, meter and time.
4. a) Why does gravity effect a path of light i.e. b) why are black holes invisible does light really get pulled towards it?
a) Explanations may take different approachs. One of these is: gravitational field creates gradient (non-uniform) where the electromagnetic path seams apparently to be curved, but, in fact, this path is the shortest space-time path and therefore a straight space-time line.
b) Light, like any other types of energetic objects, is attracted by gravity. I will vulgarize my explanation but, I hope, this will help to figure out some light behaviors in presence of a black hole.
Figure it's saturday night and you (the light) want to leave home for a party (pointing away). Your father (black hole) try to retains you at home. Option 1: You have enough energy to leave home for ever... Option 2: You have enough energy to leave home but not so much and come back home later... Option 3: You don't have enough energy and stay at home. Your friends will never see you.
How did you come to that conclusion? Gravity WARPS time, not creates it.
Anyway, as long as there is at least one particle in the universe, there will be gravity anywhere at some time ('at some time' because graavitation doesn't travel faster than light). It might be very much imperceptible, but it's there.
Gravity WARPS time? Please explain!
I am out of order but i think he or she may have come to that conclusion because of relativity. In relativity spacetime is defined by the gravitational field, how the field lines cross and or knot. If there were a place with no gravitational field there would necessarily be no spacetime. Which means there would be no "time" either. One runs into problems like this when one says time instead of spacetime.
Imagine, "warps" is just another way of saying that the geometry(the way relativists describe a particular coordinate system)of space changes around a massive(not a large body but one that posesses mass=energy) body.
Merci Vedder !
Exactly, vedder! Oh, and I'm a she...
hello i have a question
my question about gravity and how about canceling it ?
and the research of dr Abd salam at germany at this field
cancel gravity
dr Abd salam at Germany said that may be he can cancel gravity and he made a research about that and he succeeded partely saying that tha big egyption pyramed was built as no gravity at this aria
  • · Replies 33 ·
  • · Replies 67 ·
  • · Replies 16 ·
  • · Replies 23 ·
