Why dont we see color red as blue in water?
  • Context: Undergrad
  • Thread starter Thread starter think
    Color Water
The discussion centers around the perception of color, specifically why red light does not appear blue when viewed through water. Participants explore the relationship between wavelength, frequency, and the perception of color in different media, including the effects of the human visual system.
  • Some participants question why red light does not appear as a different color, such as blue, when it passes through a denser medium like water.
  • One participant suggests that the brain processes surrounding color information to determine perceived color, using an analogy related to inflation and standard of living.
  • Another participant asserts that frequency, not wavelength, determines color perception, stating that red remains red regardless of the medium.
  • A participant challenges the idea that light travels at the speed of light between interactions with atoms, suggesting that if frequency remains unchanged, wavelength should also remain unchanged until it impacts the eye.
  • There is a discussion about the relationship between energy, frequency, and wavelength, with references to quantum mechanics and Planck's constant.
  • One participant explains that the decrease in light velocity in a denser medium leads to a shorter wavelength, while frequency remains constant due to energy conservation during electron transitions.
  • Another participant mentions that the medium of the eye itself affects color perception, implying that the perception of color remains consistent despite being in water.
Participants express differing views on the relationship between wavelength and frequency in color perception, with no consensus reached on the explanations provided. The discussion remains unresolved regarding the mechanisms of color perception in different media.
Participants reference various concepts from quantum mechanics and the physics of light, but there are unresolved questions about the assumptions underlying these explanations, particularly regarding the interaction of light with matter and the perception of color.
think
Just a small question: If the wavelength of light changes in a denser medium then why don't we percieve color red as some other color? :eek:
Also, why does only wavelength changes not the frequency but not the vice versa? What determines this?
This is one possible explanation of the result that has little to do with the physics of the matter. Our brains actually takes into account all the information about the colors around the one your considering before it decides what color the wavelength should be perceived as. For a similar example, consider inflation. Let's suppose you want to know Jack's standard of living and I told you he earned $100 a week in 1935 (the wavelength). That information by itself wouldn't be too meaningful because the buying power of $100 over an extended period of time varies. But suppose i also told you how much everyone else made (surrounding wavelengths). Then you could account for inflation and roughly make out Jack's standard of living at the time. Similarly, our brain tracks all the wavelengths in the scene and decides what color each should stand for only after accounting for how lighting (and possibly other factors) alter reflected wavelengths. This is why a red brick stays red as we walk from indoors to outdoors.
Wavelength has nothing to do with color. It's frequency that matters. So, red is still red in whatever medium you're talking about. The frequency is never changed, only the wavelength.
The velocity of light is decreased in an optically denser medium, because the light is absorbed by electrons which become excited, and then decreases when the electrons go back to their rest state. The frequency of the light emitted is directly proportional to the energy level difference between the excited state and the rest state of the electron. Since they absorb and emit the same amount of energy, the frequency of the light is not changed. Instead, the wavelength of the light is changed.
I'm not saying my response was correct, but there is something i don't understand about your explanation. As light travels in between being emitted by one atom and absorbed by the next it should be traveling the speed of light because it will be moving through a vacuum in that small time interval. During those times the frequency and wavelength of light will be tightly related. If the frequency of the light is unchanged by an interaction with an atom as you claim, then between atoms, the wavelength should also be unchanged. So when the light actually impacts atoms in the eye, it will not appear any different than it was before.
That brings me to ask a deeper :redface: question: Why does it influences the frequency only but not the wavelength or velocity?
It follows from the equation E=hf, where h is Planck's constant.(what was the name of this equation again? I forgot. Check it up in any book that mentions quantum mechanics.) E is energy. A certain frequency of light is related to a certain amount of energy given out when a electron becomes excited to a new state, or gives out energy when returning to a rest state. So, the frequency is fixed, because the electron jumps from a certain position, goes to another, and then returns back to the initial position. The energy absorbed and emitted is the same, and the frequency is always the same.
Think of picking up a rock from the ground and putting it on the table. That's like a electron absorbing energy and getting excited. Then, the rock falls back onto the ground. That's like giving back out the energy and returning to a rest state. The energy absorbed and emitted is the same.
Wavelength is something we look at from a macroscopic view. Since the light is absorbed and then emitted from the electrons, there is a small time lapse(or delay) which causes the speed of the wave to slow down. By velocity = wavelength * frequency, we can see that since the frequency is unchanged, and the velocity is decreased, the wavelength is shorter. The decrease in wavelength is a consequence of the decrease in velocity, rather than being directly influenced by the action of refraction.
Why don't we see color red as blue in water?
As kuenmao mentioned above, light passing through different mediums will vary it's wavelength and speed, but frequency stays the same. And the reason your eyes always percieve the same color is because of the medium in your eyelobes. Cause even though you're in water, the light still has to pass through your eyelobes to be detected, and that medium never changes.
  • · Replies 207 ·
16K
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 22 ·
