Calculating the Integral of an Elliptical Area: How to Solve for a?
The problem involves calculating the area of an ellipse defined by the equation \(\frac{x^{2}}{a^{2}}+\frac{y^{2}}{b^{2}}=1\) using an integral. The integral in question is \(\frac{4b}{a}\int_{0}^{a}\sqrt{a^{2}-x^{2}}dx\), and participants are exploring how to evaluate this integral.
  • Participants discuss using a trigonometric substitution \(x = a \sin \theta\) and the corresponding differential \(dx = a \cos \theta d\theta\). There are questions about whether to solve for \(a\) and how to properly handle the limits of integration. Some participants express uncertainty about the expected form of the answer and the evaluation of the integral.
There is an ongoing exploration of the integral evaluation process, with some participants providing guidance on the substitution and limits of integration. Multiple interpretations of the substitution and its implications are being discussed, and while some participants express confusion, others attempt to clarify the steps involved.
Participants note that \(a\) is a constant representing the semi-major axis of the ellipse, and there is a recognition that the integral's evaluation may involve careful attention to detail in the substitution process. There are indications of mistakes in the evaluation steps that are being addressed through discussion.
tabukihna
The area of the ellipse [tex]\frac{x^{2}}{a^{2}}+\frac{y^{2}}{b^{2}}=1[/tex] is given by
[tex]\frac{4b}{a}\int_{0}^{a}\sqrt{a^{2}-x^{2}}dx[/tex] . Compute the integral.
I know I have to let [tex]x=asin\theta[/tex] and then [tex]dx=acos\theta[/tex] . Then I plug in x. Do I need to solve for a and plug that in, or am I really over thinking this?
Thanks in advance.
[tex]dx=acos\theta d\theta[/tex]
Don't omit the differential.
You don't "plug in x"; you replace x and dx in your original integral with the expressions that involve theta and its differential. Maybe that's what you meant, but it isn't what you said.
Thanks in advance.
You can't solve for a, so yes, you are overthinking this.
a is a constant (semimajor axis), so there's no need to solve for it.
Oops I had the [tex]d\theta[/tex] written down but forgot to type it.
Yes, that is what I meant, but since this is a message board I didn't think it'd be a big deal. Thanks for setting me straight about thinking too much :).
Ok I worked it out, but I'm not really sure what kind of answer I'm supposed to be getting.
Here's the work(if anything needs to be explained better please say so).
[tex]Let x=asin\theta[/tex] [tex]Then dx=acos\theta d\theta[/tex]
[tex]\frac{4b}{a}\int_{0}^{a}\sqrt{a^{2}-(asin\theta) ^{2}} acos\theta d\theta[/tex]
[tex]=\frac{4b}{a}\int_{0}^{a}\sqrt{1-sin^{2} \theta} acos\theta d\theta[/tex]
Pythagorean ID, square root and then multiply
[tex]=\frac{4b}{a}\int_{0}^{a}a^{2}cos^{2}\theta d\theta[/tex]
[tex]=\frac{4ba^{2}}{a}\int_{0}^{a}cos^{2}\theta d\theta[/tex]
Half-Angle
[tex]=4ab \int_{0}^{a} \frac{1}{2} \left ( 1+cos2\theta \right ) d\theta[/tex]
Used substitution.
[tex]=\left [ 2ab\theta \right ]_{0}^{a}+[absin2\theta]_{0}^{a}[/tex]
[tex]sin\theta=\frac{x}{a}[/tex] and [tex]\theta=arcsin\frac{x}{a}[/tex]
[tex]=\left [ 2ab*arcsin\frac{x}{a} \right ]_{0}^{a}+[ab\frac{x}{a}]_{0}^{a}[/tex]
Since [tex]arcsin(1)=\frac{\pi }{2}[/tex] and [tex]arcsin(0)=0[/tex]
[tex]=2ab\frac{\pi }{2}+ab=\pi ab+ab[/tex]
It looks like you did fine right up to the end where you evaluated your antiderivative at 0 and a. After finding the antiderivative (a function of theta), you need to undo your substitution, and get the antiderivative back in terms of the original variable, x.
Alternatively, you can change the limits of integration from values of x to values of theta. x = 0 ==> theta = 0, so that one is easy, x = a ==> theta = sin-1(a/a) = sin-1(1) = pi/2.
Either way should give you the same result.
Hmm...I thought I did. I think it should've been [tex]sin2\theta=\frac{2x}{a}[/tex] , but I don't get where else I messed up. Is that it?
I have
[tex][2ab*arcsin\frac{x}{a}]_{0}^{a}+[ab\frac{2x}{a}]_{0}^{a} = \pi ab+2ab[/tex]
Thanks for the patience.
No, your original substitution was x = a sin(theta), so x/a = sin(theta), so theta = sin-1(x/a).
You're coming out with the wrong answer for the ellipse's area.
Sorry, you lost me. Yes, that was my original substitution. Then when I'm going back to x doesn't [tex]sin2\theta=\frac{2x}{a}[/tex] ?
I'm still getting the same answer [tex]\pi ab + 2ab[/tex]
The result you're getting is incorrect.
From post 4, you have
[tex]=4ab \int_{x = 0}^{x = a} \frac{1}{2} \left ( 1+cos2\theta \right ) d\theta[/tex]
[tex]=\left [ 2ab\theta \right ]_{x = 0}^{x = a}+[absin2\theta]_{0}^{a}[/tex]
I added "x = " in your limits of integration, for emphasis and as a reminder that your antiderivative is in terms of theta, not x. In carrying out this integration, you did another substitution, u = 2theta, du = 2d(theta), but you did the integration and undid that substitution.
You still need to undo your original substitution, x = a sin(theta) OR change your limits of integration. If you undo your first substitution, you'll need to replace theta in 2ab*theta and in ab*sin(2theta).
x = a sin(theta) <==> theta = sin-1(x/a)
To answer your question, no. sin(2*theta) = sin(2*sin-1(x/a))
I believe this was my mistake all along. I was going back to x but had the sin(2theta) messed up.
I'm now getting [tex]\pi ab[/tex] for the answer.
And that's the right answer.
It's always the little mistakes. :bugeye:
Thanks for the help.
Sure, you're welcome.
Being good at calculus is partly about attention to detail.
  • · Replies 105 ·
13K
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 22 ·
