Transmission line approimation
The discussion focuses on the derivation of approximate formulas for the propagation constant (γ) and characteristic impedance (Z0) of low-loss transmission lines, specifically under the conditions where R/wL and G/wC are much less than one. The approximated formula for γ is given as γ = jw√(LC)(1 + R/2jwL)√(1 + G/2jwC). The required results for α and β are derived as α = √(LC/2)(R/L + G/C)[1 - (1/8w²)(R/L - G/C)²] and β = w√(LC)[1 + (1/8w²)(R/L - G/C)²]. The discussion emphasizes the need for retaining higher-order terms for better accuracy at lower frequencies.
  • Understanding of transmission line theory
  • Familiarity with complex numbers and phasors
  • Knowledge of square root expansions in calculus
  • Basic concepts of electrical parameters: resistance (R), inductance (L), conductance (G), and capacitance (C)
  • Study the derivation of transmission line equations in "Cheng's Field Theory" textbook
  • Learn about the impact of frequency on transmission line performance
  • Explore advanced techniques for approximating functions in electrical engineering
  • Investigate the effects of higher-order terms in transmission line modeling
Electrical engineers, students studying transmission line theory, and professionals involved in RF and microwave engineering will benefit from this discussion.
likephysics
Transmission line approximation
In the derivation of the approximate formulas of \gamma and Z0 for low loss lines, all terms containing the second and higher order powers of R/wL and G/wC were neglected in comparison with unity. (R/wL<<1 and G/wC<<1)
gamma=jw*sqrt(LC)*sqrt(1+R/jwL)*sqrt (1+G/jwC)
approximated to
gamma = jw*sqrt(LC)*(1+R/2jwL)*sqrt(1+G/2jwC)
gamma is the propagation constant which is equal to alpha+j beta
At lower frequencies, better approximation may be required. find new formulas for \gamma and Z0 for low loss lines that retain terms containing (R/wL)^2 and (G/wL)^2
Required result is
alpha = sqrt(LC/2)*(R/L+G/C)*[1-(1/8w^2)*(R/L-G/C)^2]
beta = w*sqrt (LC)*[1+(1/8w^2)*(R/L-G/C)^2]
I tried expanding the term
sqrt(1+R/jwL) using square root expansion :
1+(1/2)*R/jwL-(1/8)*(R/jwL)^2
did the same for sqrt (1+G/jwC)
I am unable to get the desired result. Any help.
FYI, this is prob 9.7 in cheng.
That looks fine to me...what do you get when you multiply everything out?
  • · Replies 0 ·
  • · Replies 18 ·
