Configuring LinkSys BEFW 11S4 Wireless Router
  • Thread starter Thread starter alanveron
    Router Wireless
The discussion revolves around configuring the LinkSys BEFW 11S4 wireless router, addressing issues related to accessing the configuration interface and setting up the router for internet connectivity. Participants explore both manual and automated methods for configuration, as well as considerations for optimizing internet speed for connected devices.
  • One participant expresses difficulty accessing the router's configuration page at http://192.168.1.1 and questions whether manual configuration is possible.
  • Another participant suggests checking if an IP address has been issued by the router and recommends using the command prompt to find the default gateway.
  • A participant recalls that the wireless access point may not be enabled initially and advises connecting via an ethernet cable for setup.
  • It is noted that 192.168.1.1 is a local IP address and not an internet site.
  • Several participants emphasize the importance of following specific instructions for configuration and mention the availability of tech support from Linksys.
  • One participant inquires about configuring one PC for faster internet access, leading to a discussion about bandwidth sharing among devices connected to a NAT device.
Participants generally agree on the need to connect via ethernet for initial setup and the significance of following the router's manual. However, there is no consensus on the best method for optimizing internet speed for individual PCs, with differing views on the feasibility of prioritizing bandwidth.
Some participants assume that the wireless access point is off by default, and there is uncertainty regarding the specifics of bandwidth allocation among devices connected to the router.
Users experiencing difficulties with configuring LinkSys routers, individuals interested in optimizing network performance, and those seeking technical support for home networking issues.
alanveron
wireless router...
i bought a new wireless router from LinkSys...model no. is BEFW 11S4...i was asked to go to http://192.168.1.1 to configure my connection...but i can't even go to http://192.168.1.1...so how can i configure my connection?
Must i go to the site to configure it or i can configure it manually without visiting the site?
Computer science news on Phys.org
did you get issued an IP address from the Wifi Router?
Open CMD and type ipconfig to find out, look for the default gateway, this will be your wifi router... open IE and put in the this IP address to configure the router...
IIRC, the wireless access point is not turned on when you initially turn the router on. You'll need to actually plug into it with an ethernet cable to be able to set it up and turn the wireless access point on.
- Warren
Remember that 192.168.1.1 is not a site on the Internet. It is the IP address that your router assumes on your home network.
so how to configure it?
Plug a cable into it, then direct a browser to http://192.168.1.1, then follow directions. Ask specific questions, please.
- Warren
yeh good point, I thought he had pluged in an ethernet cable :-/
No offense, but most manuals have quite specific and easy to follow directions...
True. And Linksys has pretty good tech support, I've dealt with them in the past and had no problems.
Just don't ask them the meaning of life.
uhmmm, what is "the meaning of life" ? as your post mentioned ?
i am using wireless router now to link to 2 of my pc...so can i configure one of the pc to be faster on surfing the net?
unless you want to use a Packetshapper or some Nbar on a router (cisco) you will find it difficult giving one PC morebandwith than the other, typically any PC behind a NAT device will share the bandwidth at the NAT device...
  • · Replies 24 ·
  • · Replies 19 ·
14K
