Register to reply
Parallel transport and geodesics
by dianaj
Tags: geodesics, parallel, transport
Share this thread:
dianaj
#1
Oct16-09, 09:34 AM
P: 16
A vector field is parallel transported along a curve if and only if the the corariant derivative of the vector field along the path is 0. That is
[tex]\frac{d}{d\lambda} V^\mu + \Gamma^\mu_{\sigma \rho} \frac{dx^\sigma}{d\lambda} V^\rho = 0[/tex]
This is basically what every book says. But what exactly does it mean?
1) if you have a vector (field), there is a specific set of paths, that - when you transport the vector along them - will leave the vector 'unchanged'. That means that there are certain paths that change the vector i.e. stretches it or turns it or whatever.
2) the equation describes how the vector (field) should change when you move it along a certain path (any path you choose) in order to keep it constant with respect to the connection.
I can see arguments for both interpretations and it's driving me crazy. ;)
In flat space space you can parallel transport a vector in any direction you want - there are no right or wrong paths. This speaks for 2).
A geodesic is a path that parallel transports a vector that is the tangent vector to the path itself. This speaks for 1) (i.e. for a vector there is a specific parallel transport path, for the tangent vector to the path this is the path itself)
If you have a sphere and parallel transport the vector
[tex]V = (1,0)[/tex]
around a circle of constant [tex]\theta[/tex] (altitude) the vector changes like
[tex]V(\theta,\phi) = \left(\cos(\phi \cos\theta), \frac{-1}{\sin \theta}\sin(\phi \cos\theta)\right)[/tex]
This speaks for 2) as you can clearly choose any path (any altitude (except the north/south pole of course)). It also shows the vector is not constant with respect to the path (the path parameter being [tex]$\lambda = \phi$[/tex]) as it changes when you go round.
So...which one is it? What point am I missing? ;)
Phys.Org News Partner Science news on Phys.org
Scientists discover RNA modifications in some unexpected places
Scientists discover tropical tree microbiome in Panama
'Squid skin' metamaterials project yields vivid color display
dx
#2
Oct16-09, 10:18 AM
HW Helper
PF Gold
dx's Avatar
P: 1,961
Vectors can be parallel transported in any direction. There are no preferred directions for parallel transport.
dx
#3
Oct16-09, 10:29 AM
HW Helper
PF Gold
dx's Avatar
P: 1,961
In (1), you seem to be implying that somehow it is that path that changes the vector. The vector is defined in the tangent space at a point p. If you have a path through p, this vector may be parallel transported along it to another point. You also refer to vector fields instead of vectors, so again I don't quite understand what you're implying.
pervect
#4
Oct16-09, 03:55 PM
Emeritus
Sci Advisor
P: 7,659
The formal definitions of parallel transport are very good for calculation, but for understanding the idea I prefer geometrical constructs, like Schild's ladder.
http://en.wikipedia.org/wiki/Schild%27s_ladder
Consider a parallelogram - if opposing sides are of equal lengths, the opposing sides are parallel. And we know how to calculate lengths if we have a metric, so there isn't any problem in the notion of "sides of equal length".
So if we have a metric, the idea that the sides of a parallelogram "should be" parallel if the parallelogram is small enough gives a unique idea of parallel transport. As long as you don't mind representing vectors as line segments, that is.....
wofsy
#5
Oct17-09, 08:08 AM
P: 707
Quote Quote by dianaj View Post
When you have a Riemannian connection a vector parallel transported along a curve keeps its length and its angle to the tangent direction of the curve. If two vectors are parallel transported along the same curve, the angle between them remains constant.
If you parallel transport a vector around a closed curve then the vector may come back to a different vector even in a flat space. Also the change in the vector when it returns to the starting point may depend on the curve, even in a flat space.
yuiop
#6
Oct17-09, 11:39 AM
P: 3,967
Did you mean latitude?
A vector field is parallel transported along a curve if and only if the corariant derivative of the vector field along the path is 0. That is
I think a better description might be "A path is a geodesic (the equivalent of a straight line in curved space) if and only if the covariant derivative of the vector field along the path is 0." I am not an expert on this subject so I welcome the real experts to correct the terminology and semantics.
The specific set of paths that leave the vector unchanged are called geodesics.
This is probably the better definition because a vector can be parallel transported along a path without the covariant derivative remaining zero. For example a vector can be parallel transported along a line of constant latitude on the globe and not necessarily still be parallel to itself on returning to the start point. This is because a line of latitude (other than the equator) is not on a great circle and is not a geodesic. This deviation or precession of the vector when parallel transported along a path (the non zero covariant derivative value) is a measure of how much the path deviates from the equivalent of a straight line in curved space (a geodesic).
It might help to think of a imaginary parallel transport vehicle. This vehicle is designed so that whenever the vehicle turns x degrees clockwise, the vector it is transporting turns x degrees anticlockwise (or vice versa) so that on a two dimensional plane the transported vector always remains parallel to its starting position. Now imagine the following journey. The vehicle starts at the equator and heads to the North pole. At the North pole it makes a 90 degree turn clockwise and heads South back towards the equator. At the equator it makes another 90 degree turn clockwise and heads back to its starting point and makes a final 90 degree turn so that the vehicle is aligned with its original heading. The vector it was transporting is now rotated 270 degrees anticlockwise relative to its starting position. The internal angles of the triangle formed by this journey add up to 270 degrees rather than the usual 180 degrees we would normally expect for a triangle in flat space. If this vehicle has its wheels locked in the straight ahead position it will be forced to follow a great circle or geodesic on the globe and its transported vector will not precess from its original direction when it returns to its starting point. Now if the vehicle follows a line of latitude it has to turn its front wheels to stay on the line of latitude because if it tries to keep pointing straight ahead it will be forced to deviate from the line of latitude. This turning of the front wheels of the vehicle to stay on the line of latitude, causes the vector it is transporting to precess. In a nutshell, deviating from a geodesic path causes precession of the parallel transported vector.
I think the source of your confusion is the use of the term "parallel transport" for something that is not necessarily parallel transported in the casual sense.
Page 26 of this document
http://www.shef.ac.uk/physics/teachi..._lecture_8.pdf shows a nice trick with a cone on sphere that may help visualise the situation.
dianaj
#7
Oct17-09, 01:37 PM
P: 16
Quote Quote by kev View Post
That's a nice way to think of it. It kind of makes sense. :)
Thank you for the link, it looks good. Before I look at it more closely I just have a few questions.
The change of coordinates that they calculate, describe how the vector will look, when it has been transported to a new point, from the new point's view, right?
Also, the figure at page 24 is sort of how I thought a tangent vector to the equator would be parallel transported around the equator - i.e. along its own geodesic. I thought that transport around a circle in flat space (which is sort of like the top part of the sphere) would keep the vector pointing 'up' (whith up I here mean at 12 o'clock in the drawing).
yuiop
#8
Oct17-09, 03:16 PM
P: 3,967
I think the diagram you refer to is a little misleading. Starting at the 3 o'clock position with the vector pointing in the 12 o'clock direction, the transported vector should continue to point roughly in the 12 o'clock direction.
The equation that they give for the precession of a vector transported along a line of latitude is:
[tex]\alpha = \phi*\cos(\theta)[/tex]
If the vector is transported half a circle around a line of latitude the equation becomes:
[tex]\alpha = \pi*\cos(\theta)[/tex]
At the equator [itex]\theta[/itex] is 2*pi so [itex]\alpha = 0[/itex] so there is no precession and the vector is pointing in the same direction as the vehicle.
Very near the North pole [itex]\theta[/itex] is close to zero (say 0.1 radians) so for a half circle path [itex]\alpha = \pi*\cos(0.1) = 0.995*\pi [/itex] radians, so by the time the vehicle has travelled to the 9 o'clock position in the diagram the vector will have been rotated nearly half a turn clockwise relative to the vehicle (and in the plane tangential to the surface the vehicle is on) and still pointing roughly in the 12 o'clock direction. (The vector is now pointing roughly to the rear of our imaginary vector transportation vehicle.)
I think that is correct.
dianaj
#9
Oct19-09, 02:45 PM
P: 16
Thank you for your answers - I think my understanding has improved. :)
Register to reply
Related Discussions
Parallel transport on the sphere Calculus & Beyond Homework 1
Parallel Transport Special & General Relativity 20
Parallel transport approximation Special & General Relativity 1
Parallel transport Introductory Physics Homework 0
Lie transport vs. parallel transport Differential Geometry 10
