Im resarching on pentaquarks and this showed up?
  • Context: Graduate
  • Thread starter Thread starter taylordnz
This discussion focuses on the concept of pentaquarks and their relationship with instantons in quantum field theory (QFT). Instantons are identified as nonperturbative, topological effects crucial for understanding the dynamics of quantum chromodynamics (QCD). The discussion highlights the significance of the Pontryagin index in classifying gauge configurations and the role of instantons in breaking chiral invariance, which is essential for modeling hadrons. Key references include works by Marko Kolanovic and Diakonov for further exploration of these concepts.
  • Understanding of quantum field theory (QFT)
  • Familiarity with quantum chromodynamics (QCD)
  • Knowledge of solitons and their properties in D-dimensional space
  • Concept of topological charges, specifically the Pontryagin index
  • Study the instanton model of pentaquarks in detail
  • Explore the implications of the Pontryagin index in gauge theory
  • Read Diakonov's papers on instantons and vacuum tunneling
  • Investigate the role of instantons in breaking chiral symmetry in QCD
Researchers and students in theoretical physics, particularly those focusing on quantum field theory, quantum chromodynamics, and the study of exotic hadrons such as pentaquarks.
taylordnz
im resarching on pentaquarks and this showed up?
what is it
The definition wildly varies usually in the literature, so be careful.
Instantons are usually associated with nonperturbative, topological effects in QFT.
In the case of the pentaquark, if memory serves, there's something called the instanton model of the pentaquark.. and that means something else.
instantons are indeed involved in nonperturbative effects : they miss every order of perturbation (think about exp[-1/x^2] at x~0)
Maybe you know what a soliton is : if you consider D-dimensional SPACE, a soliton is a localized solution of the equations of motion, with this friendly feature : it has a finite action. Typically, a kink or a breather. The very fundamental stuff, is that solitons are typically able to interpolate between different boundary conditions at infinity. At infinity, one of course expect to have the vacuum, so the soliton actually interpolates between two different vacua.
OK, now back to the instanton : this is almost trivial, an instanton is exactly the same think as a soliton, except for the fact that it sits in D-dimensional EUCLIDIAN SPACE-TIME. The way one interprets instantons, is as a tunnel effect : it "instantaneously" switches a new vacuum state for the field. That is what led 't Hooft in the middle of the 70's (if I remember correctly) to first coin the term "instanton".
The reason why instantons are so usefull in QCD, is because the gauge group, SU(3) for color, exhibits a non-trivial topology. The boundary condition at infinity for a gauge configuration can be caracterized by an integer number, which is called "Pontryagin index". This is closely related to the well-known "Chern-Simons number". It is just an integer which allow one to classify the solution. I don't know any physical interpretation for the Pontryagin index. It is really a topological charge of the field, and appears because of non-trivial mappings with different winding numbers.
The reason why instantons are considered so fundamental in QCD, is that they are able to break chiral invariance. What has been done is to consider a gaz of instantons (which is not a true solution because the equations are not linear), which is suppose to model the gluonic field, and then incorporate valence quarks into this gas. This is a very appealing model for hadrons. Besides, it is an efficient way to model hadrons.
References :
A "final exam" at NYU by Marko Kolanovic (thanx Marko !) on "Instantons and Vacuum tunneling" :
eprints.fizika.org:2101/archive/00000027/01/seminar.ps
Please read Diakonov whenever you want to learn about QCD and instantons :
nac21.uv.es/pdf/9602375
or arXiv:hep-ph/9602375 v1 23 Feb 1996 (this is the same)
A very good review on instantons by Diakonov :
arXiv:hep-ph/0212026
  • · Replies 41 ·
10K
