Why Do Different Books Use X=Acos(wt) and X=Asin(wt) for Oscillations?
  • Thread starter Thread starter SAT2400
The discussion clarifies the use of the equations X = A cos(ωt) and X = A sin(ωt) in modeling oscillations. The choice between these equations depends on the initial conditions of the motion: use X = A sin(ωt) when the oscillation begins from the equilibrium position, and X = A cos(ωt) when it starts from the maximum amplitude. Both equations represent the same harmonic motion but are phase-shifted versions of each other, reflecting the same underlying circular motion principles.
  • Understanding of harmonic motion and oscillations
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Knowledge of angular velocity (ω) and amplitude (A)
  • Concept of uniform circular motion and its projections
  • Study the relationship between circular motion and harmonic motion
  • Explore phase shifts in trigonometric functions
  • Learn about initial conditions in oscillatory systems
  • Investigate applications of sine and cosine functions in physics
Students of physics, educators explaining oscillatory motion, and anyone interested in the mathematical modeling of wave phenomena.
SAT2400
X= Acos(wt)?? X= Asin(wt)??
X= Acos(wt)??
X= Asin(wt)??
Which is right? in some books, x = A sin(wt), while in other books, x= Acos(wt)...
I'm confused.
Please explain this to me. Thank you very much.
. f(x) is the projection of a particle moving in a uniform circular motion with radius A and angular velocity ω. If you take the projection on x-axis, then f(x) = Acosωt.
Ιf you take the projection on y axis, then it is f(x) = Asinωt
use x=Asin(wt) if the oscillation is starting from the equilibrium position (b/c if u look at a sin curve, it starts at a value of 0), and if it is starting at the amplitude, use x=Acos(wt). (b/c looking at a cosine curve, it starts at the amplitude)
But since sin and cos are really the same functions except shifted over, these two equations are both true and essentially mean the same thing.
12K
9K
11K
