Circuit for determining the internal resistance of a dry cell
To determine the internal resistance of a dry cell, set up a circuit that includes a variable resistor (rheostat) in series with an ammeter and a voltmeter. Measure the open circuit voltage to find the EMF, then apply a load to the battery and monitor the voltage drop across the load while measuring the current. The internal resistance can be calculated by analyzing the voltage drop and the current flowing through the circuit, with a recommended voltage drop of around 10% for rechargeable cells like NiMH or NiCd.
  • Understanding of basic electrical concepts, including EMF and resistance
  • Familiarity with circuit components such as ammeters and voltmeters
  • Knowledge of variable resistors and rheostats
  • Ability to perform calculations involving voltage, current, and resistance
  • Research how to measure open circuit voltage effectively
  • Learn about the characteristics of NiMH and NiCd batteries
  • Explore circuit design principles for measuring electrical parameters
  • Study Ohm's Law and its application in circuit analysis
Electronics enthusiasts, students in physics or electrical engineering, and hobbyists interested in battery performance analysis will benefit from this discussion.
jackmannn
What sort of circuit would I have to set up to figure out the internal resistance of a dry cell? Also, what would i need to be measuring and doing etc, to find this internal resistance?
Thanks, Jack.
A battery is considered to be an EMF in series with a resistor.
You can measure the EMF by measuring the open circuit voltage of the battery. There is no voltage drop across a resistor if there is no current flowing through it.
To put a load on the battery and measure the current and voltage, you could use something like the attached diagram.
A voltmeter monitors the output voltage. A variable resistor R is placed in series with the ammeter.
You can monitor the voltage while the heavy load (R) is placed across the battery. A large rheostat would be suitable for R.
Suppose R makes the output voltage drop to half. Then you could say that R is equal to the internal resistance.
You can calculate the value of R by measuring the voltage across it and the current through it.
The voltage does not have to drop to half. If you were testing a rechargeable cell, a NiMH or NiCd cell, you would not do this because these can deliver very large currents. So, maybe a 10% drop would be OK for these.
You just calculate the value of the internal resistance knowing the current flowing and the voltage drop between no load and the measured load.
  • · Replies 105 ·
14K
  • · Replies 48 ·
9K
