| Thread Closed |
HELP geometric probability: area of a square and conditional probability |
Share Thread | Thread Tools |
| Oct19-09, 06:23 PM | #1 |
Chose a point at random in a square with sides 0<x<1 and 0<y<1. Let X be the x coordinate and Y be the y coordinate of the point chosen. Find the conditional probability P(y<1/2 / y>x). 2. Relevant equations No clue. 3. The attempt at a solution Apparently, according to the prof, the square need not be equilateral??? And this is where I get stumped. No clue here. Any help would be great. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Oct19-09, 07:55 PM | #2 |
Mentor
Try drawing a diagram of your square. BTW, a square is equlateral, so I don't know what your prof was talking about, or maybe you misunderstood him/her.
P(y < 1/2 | y > x) asks for the probability that a point's y coordinate is less than 1/2, given that the point is in the triangular region above and to the left of the line y = x. There is some geometry here that you can use. |
| Oct19-09, 09:59 PM | #3 |
Thanks for your answer, Mark 44.
Let's assume that a square has equilateral sides (which it does, usually). That means that y=x! So P(y>x)= 0 Right!! Also, P(y<1/2) = .5, right?? I'm still pretty lost, any help is appreciated!! :) Dania |
| Oct19-09, 10:30 PM | #4 |
Recognitions:
the sides of the square are given (and by definition equal), so i don't really understand teh equilateral discussion...
anyway, the area of the square is 1 the probability of a point being in the square is 1 you shouldn't have to work too hard to convince yourself, that the probabilty of finding the point in a given region is in fact equal to the area of the region in this case use that fact with the conditional probability equation to solve |
| Oct20-09, 05:43 AM | #5 |
[/quote]I'm still pretty lost, any help is appreciated!! :) Dania[/QUOTE] Draw a picture. To start with, of course, draw the square [itex]0\le x\le 1[/itex], [itex]0\le y\le 1[/itex]. Now draw the line y= x. That will be a diagonal of the square. Requiring that y> x means we are in the upper half of that square, above the diagonal. Draw the line y= 1/2. Saying that y< 1/2 means we are below that line but still in the upper half of the square, above the diagonal. You should see that this area is a triangle. What is the area of that triangle? What percentage is it of the upper half of the square? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: HELP geometric probability: area of a square and conditional probability
| (CONDITIONAL PROBABILITY) Which probability would you expect to be greater? | Precalculus Mathematics Homework | 1 | ||
| Probability - Conditional Probability | Calculus & Beyond Homework | 0 | ||
| probability - conditional | Biology, Chemistry & Other Homework | 2 | ||
| Joint probability from conditional probability? | Set Theory, Logic, Probability, Statistics | 10 | ||
| conditional probability help plz | Engineering, Comp Sci, & Technology Homework | 1 | ||
