Why Must the String Be Parallel to the Surface in Friction Experiments?
  • Thread starter Thread starter munchy35
    Concept Friction
The discussion centers on the necessity for the string to be parallel to the surface in friction experiments involving a block and hanging masses. When the string is parallel, the horizontal component of the pulling force directly opposes the frictional force, while the vertical component reduces the normal force acting on the block. If the string is not parallel, the vertical component would increase the normal force, thereby increasing the frictional force, which complicates the measurement of friction. This understanding is crucial for accurately assessing frictional forces in experimental setups.
  • Understanding of basic physics concepts, particularly friction and normal force.
  • Familiarity with vector components of forces.
  • Knowledge of experimental setups involving blocks and hanging masses.
  • Basic grasp of Newton's laws of motion.
  • Research the relationship between normal force and frictional force in physics.
  • Study vector decomposition of forces in two dimensions.
  • Explore experimental methods for measuring friction, such as using a force sensor.
  • Learn about the coefficient of friction and its implications in different materials.
Students in physics courses, educators teaching mechanics, and anyone conducting experiments related to friction and forces in a laboratory setting.
munchy35
Alright, I understand that friction needs to be parallel to the surface, but I'm confused on why.
So if a string is attached to a block that connects to hanging masses in a lab, and you're pulling the block to measure the friction force, why does it have to be parallel to the surface?
and would the frictional force change if the string were not parallel?
no equations.
I think that it has to be parallel so the object does not slide or move? and the frictional force would change it the string were not parallel i just don't know why... maybe it would cause the force needed to pull the block to increase? I'm confused on this concept.
help?
no equations.
help?
When you pull the block with a string like that, the vertical component of the force from the string on the block serves to lighten the block (lower its normal force on the surface), and the horizontal component of the string force is what opposes the frictional force, and provides sideways acceleration if that component is larger than mu*N.
  • · Replies 38 ·
  • · Replies 20 ·
  • · Replies 16 ·
