How Do You Solve a Vector Mechanics Problem in Polar Coordinates?
  • Thread starter Thread starter Bobafable
    Mechanics Vector
The discussion focuses on solving a vector mechanics problem involving a block moving down the side of a cylinder with a radius of X and an initial horizontal velocity of Vo m/s. The derived formula for the maximum angle of contact with the cylinder is θ = cos ^(-1) (2/3 + Vo^2/(3gX)). The user seeks clarification on how to represent this problem in polar coordinates, as their instructor requires solutions in both normal tangential and polar coordinates for grading purposes.
  • Understanding of vector mechanics principles
  • Familiarity with normal tangential coordinates
  • Knowledge of polar coordinates in physics
  • Basic calculus for deriving equations
  • Study the derivation of equations in polar coordinates for mechanics problems
  • Learn how to convert between normal tangential and polar coordinates
  • Explore the application of conservation of energy in cylindrical motion
  • Investigate the role of frictionless surfaces in mechanics problems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for methods to teach coordinate transformations in motion problems.
Bobafable
I have a block/particle that has an initial velocity of Vom/s horizontally and its starting at the top and it is moving down the side of a cylinder with a radius of X. Assume no friction. What is the maximum angle at which the block/particle will remain in contact with the cylinder?
So I derived it in normal tangential coordinates and got that
theta = cos ^(-1) ( 2/3 +Vo^2/(3gX))
Which I am confident is correct. But I also need to figure out how to do it in polar coordinates. So if anyone knows how to do it or knows where to start I would be greatful for any type of help!
Thanks
BOB
Welcome to PF!
Hi BOB! Welcome to PF! :smile:
(have a theta: θ and try using the X2 and X2 tags just above the Reply box :wink:)
I don't understand :redface:
it's a cylinder, so normal and tangential coordinates are polar coordinates, aren't they? :confused:
Yes, I believe they are but my teacher asked me specifically to do them in both coordinates and the problem is broken up into 50% of the points are distributed to each coordinate system.
I have to get each coordinate system correct to get any points at all. So I kinda need to be sure that it is right. If they are the same, then how would I basically do the same work but represent it differently or sufficiently explain that they are the same. Or is there a way that I can do it polar that's different than my previous way.
  • · Replies 30 ·
14K
