Calculate missing mass from given impulse
  • Thread starter Thread starter siemieniuk
    Impulse Mass
The mass of the Agena launch vehicle was calculated to be approximately 956 kg based on the impulse exerted by the Gemini spacecraft. The impulse was determined to be 6230 N-s, resulting from a constant thrust of 890 N applied over 7 seconds. Using the relationship between force, mass, and acceleration, the calculation utilized the change in velocity of 0.93 m/s to derive the Agena's mass. This method provides a reliable estimation, although actual values may vary slightly.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with the concept of impulse in physics
  • Basic knowledge of momentum and its calculations
  • Ability to manipulate algebraic equations for solving mass and acceleration
  • Study the principles of impulse and momentum in classical mechanics
  • Learn how to apply Newton's laws in real-world scenarios
  • Explore advanced calculations involving thrust and acceleration in aerospace engineering
  • Investigate the historical context and specifications of the Gemini and Agena spacecraft
Aerospace engineers, physics students, and anyone interested in spacecraft dynamics and impulse calculations will benefit from this discussion.
siemieniuk
hey all... really struggling with how to attack this question:
On September 12, 1966, a Gemini spacecraft piloted by astronauts Conrad and Gordon met and docked with an orbiting Agena launch vehicle. With plenty of fuel left in the spacecraft , NASA decided to determine the mass of the Agena. When coupled, Gemini's motor was fired, exerting a constant thrust of 890 N for 7 s. As a result of that little nudge, the Gemini-Agena sped up by 0.93 m/s. Assuming Gemini's mass as a constant 34 x 10^2 kg (3400 kg), compute the mass of the Agena.
- I managed to calculate the impulse as 6230 N-s, which causes a momentum change of 6230 kg-m/s. where do I go from here??
thanks
[tex]\Delta p = Mv_2 - Mv_1 = M\Delta v = 0.93M[/tex]
Solving for the mass of Agena should be simple from here; note that M is the combined mass of the system.
To calculate the missing mass of the Agena, we can use the formula for impulse: impulse = force x time. In this case, the impulse is given as 6230 N-s and the time is 7 seconds. So, we can rearrange the formula to solve for force: force = impulse / time. This gives us a force of approximately 890 N.
Next, we can use the formula for force: force = mass x acceleration. Since the Agena was already in motion, we can assume that the acceleration is the same as the change in velocity (0.93 m/s). Plugging in the force of 890 N, we can solve for the mass of the Agena: mass = force / acceleration. This gives us a mass of approximately 956 kg for the Agena.
Therefore, the mass of the Agena can be estimated to be around 956 kg based on the given information. It's important to note that this is only an approximation and the actual mass of the Agena may vary slightly.
  • · Replies 19 ·
