Thread Closed
Quantam Griffiths 2.47 Finite Square Well
Share Thread Thread Tools
Oct20-09, 10:17 AM   #1
Consider double finite square well with
-Vo; -(a+b/2) < x < -b/2
V(x) = 0; -b/2 < x < b/2
-Vo; b/2 < x < a + b/2
0; otherwise
Sketch the ground wave function Psi(n=1) and the first excited state Psi(n=2) for
1. b = 0
2. b~a
3. b >> a
So...
for b=0
This is just the normal finite potential well. In particular, we can consider even and odd solutions.
the transcendental equation is
odd: tanz = ((zo/z)^2 - 1)^1/2
even: -cotz = ((zo/z)^2 - 1)^1/2
z=ka...zo=a(2mVo)^(1/2)/h_bar
k=(2m(E+Vo))^(1/2)/h_bar
As a result...for both even and odd...we get E_n + Vo ~ ((n*pi*h_bar)^2)/(2m(2a)^2)
*Note* even though i included the above information, griffiths says "no computations!" "qualitative only."
First Idea
For x< -a...Ae^(kx) (even)...-Ae^(kx) (odd)
For x > a....Ce^(-kx)
i.e. => for these regions shape of Psi (n,x) is very simple, but If I was to graph for n=1 and n=2 on the same graph...would the n=2 state be higher? (i.e. higher y value for the same x values in this region)?
For -a < x < a...
I'm confused on the shape of the graph in this region...
Do i construct for odd and even solutions?
i.e. => like pics. on pg 32 (except for sin and cos as well)
(the pics. on pg 32 are graphs of sin((n*pi/a)x) for n=1,2,3)
then for b~a and b>>a....the results are similar since a well with width a and width 2a have the same physics
Second Idea
This is supposed to just mirror the results of the infinite square well.
Particularly...we have e^(kx) (far left region) and e^(-kx) (far right region)
Also, the graph inside the well would be of form sin((n*pi/2a)x)...
I understand when we did the derivations of the infinite square well we got this result because of the B.C. #1...the continuity of Psi...as a result sin(2ka)=0...=> k=n*pi/2a
I'm confused because griffiths says no computations. Because of that statement, I infer to look back to problems we have done to see how to pursue this problem. As a result, only time we have dealt with finite square well...we didn't even graph Psi...only got information for bound states and scattering states...in particular...no question in the text asks you to graph Psi for finite square well...as a result...only time we graphed Psi for something similar was delta function potential and infinite square well. Obviously, the infinite square well is more similar. So...should I do what my gut tells me and treat each well as Psi(n,x)=sin((n*pi/a)x)
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Tags
finite square well, griffiths
Thread Tools
Similar Threads for: Quantam Griffiths 2.47 Finite Square Well
Thread Forum Replies
QM: Finite square well with V>0 Advanced Physics Homework 4
QM - finite square well Advanced Physics Homework 3
Transmission over a finite square well Advanced Physics Homework 1
Finite Square Well Quantum Physics 1
Finite square well Quantum Physics 5
