Finding Critical Values of f(x) = (1x+10)/(x^2+x+1)
  • Thread starter Thread starter apiwowar
The discussion revolves around finding the critical values of the function f(x) = (1x+10)/(x^2+x+1) by taking its derivative and applying the quotient rule.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the process of taking the derivative using the quotient rule and setting the numerator equal to zero to find critical values. Questions arise regarding the simplification of the resulting expression and the application of the quadratic formula.
Some participants provide guidance on the simplification of the square root and the division by 2, while others seek clarification on the steps taken and the resulting values. Multiple interpretations of the simplification process are being explored.
There is a noted discrepancy between the original poster's results and those suggested by other participants, indicating potential misunderstandings in the simplification steps.
apiwowar
so the question is to find the critical values for this function
i know that to find the critical values you have to take the derivative of the function. to do that you have to do the quotient rule
so you get
f'(x) = (x^2+x+1)(1)-(1x+10)(2x+1)/(x^2+x+1)^2
after cleaning it up i got (-x^2-20x-9)/(x^2+x+1)^2
so you set the numerator equal to 0 and solve it using the quadratic equation so after that you get
(20 +- sqrt (400 - 36))/-2
after simplifying i got
-10 +- sqrt364
but the website says that is wrong
where did i go wrong?
so you get
-10 +- sqrt364
You forgot to divide sqrt(364) by 2. I get x = -10 +/- sqrt(91)
Your last step should have (1/2)sqrt(364) and can be simplified.
how exactly did you get sqrt(91)?
364 divided by 2 is 182 so where does 91 come from?
because
[tex]\frac{\sqrt{364}}{2} = \frac{\sqrt{364}}{\sqrt{4}} = \sqrt{ \frac{364}{4}}[/tex]
o ok, thanks a lot
  • · Replies 20 ·
