| Thread Closed |
Generator Shaft Power (Input) to Generator Out |
Share Thread |
| Oct20-09, 02:58 PM | #1 |
Hi,
I am working on a project and my friend said to me the gas turbine shaft power is 'x' amount of power. It is directly coupled to a generator so the power to the generator is the same 'x' amount of power. How does that shaft power relate to the output of the generator? The shaft spins the rotor shaft with the same power due to direct coupling but I'm missing the direct relation between the two. The question may not be stated properly but please bare with me. Thanks in advance. |
| Oct20-09, 03:14 PM | #2 |
Recognitions:
The generator will put out some level of power lower than the SHP required to drive it due to inefficiencies of the generator itself. Losses in the generator coupled with things like rotor windage all combine to require more power to drive it than what you get out of it.
| Thread Closed |
Similar discussions for: Generator Shaft Power (Input) to Generator Out
| Van De Graff Generator: Explanations to why object repel generator | Introductory Physics Homework | 1 | ||
| Van de Graff Generator: Electrostatics, why do objects repel the generator | Advanced Physics Homework | 0 | ||
| Flywheel Generator - Split from Propane Solar Collector/Generator Thread | Mechanical Engineering | 52 | ||
| Power Generator | Classical Physics | 3 | ||
| Small electric generator, driven by a small engine shaft | Mechanical Engineering | 11 | ||
