Thread Closed
Mu without Ff
Share Thread
Oct20-09, 03:49 PM   #1
Unhappy
Mu without Ff
We are doing a lab nearly verbatim to the one at this link, http://dev.physicslab.org/Document.a...nsSoftball.xml However, under #6 in data and procedure I had forgotten to measure frictional force. Is there anyway to find mu or force of friction using the mass of the ball, initial velocity, time in air, distance thrown form box, mass of box and packaging, Fn, and box displacement?
2. Relevant equations
Inelastic collision formula
momentum formulas
3. The attempt at a solution
N/A stumped without formula to find mu or Ff, data not collected so I don't know how to work the real problem which I can do otherwise. Vf could also help me find Mu by using (0.259kg(vf-0m/s/0.63s))/2.54N = mu
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct20-09, 04:25 PM   #2
Recognitions:
Homework Helper Homework Help
You can find mu if you can take a bit of cardboard to a floor surface similar to the one you used in the experiment. Put any known mass on the cardboard and pull it along the floor with a force scale. If you can't get your hands on a scale, use an elastic band, measure its stretch, then find some way to achieve that same stretch with known forces. Likely you can look up the mass of coins and calculate their mg if no easier method comes to mind!
Oct20-09, 04:30 PM   #3
Thanks
Thread Closed
Tags
coefficient, friction, lab, momentum
