| Thread Closed |
Magnetic fields do no work? How come... |
Share Thread | Thread Tools |
| Oct27-09, 09:50 AM | #52 |
Magnetic fields do no work? How come...Claude |
| Oct27-09, 10:12 AM | #53 |
Mentor
Enough already. We are wasting each other's time. |
| Oct27-09, 11:59 AM | #54 |
That pretty much sums it up. If the current increases, so does the H field, and the electrons move further inward or outward. Then the lattices follow the electrons further in or out. Thus the H field determines where the electrons move and how far. The lattice tags along like an obedient shadow due to E force between lattice and electrons. That is prima facie evidence that the H field is primarily what determines if the wires attract or repel, and the magnitude of the force. The E field definitely participates, but is not what determines the above. H force moves the electrons. Lattice tags along due to E force. It's that simple. H is primary, with E secondary. Case closed. Claude |
| Oct27-09, 12:25 PM | #55 |
Mentor
The reason for this seemingly nitpicking discussion is one of understanding the Lorentz force law, which is the source of all the derived "right-hand rules". |
| Oct27-09, 12:29 PM | #56 |
This paper helped me understand it. :
http://academic.csuohio.edu/deissler..._77_036609.pdf |
| Oct27-09, 12:53 PM | #57 |
I certainly do not believe that a magnet is doing work on the rubber ball. But the rubber ball does not ascend if not for the mag force. So it is really splitting hairs to argue which force is responsible for the rubber ball ascending. The mag force acting on the steel ball is what ultimately lifted both balls. The steel ball was lifted by the magnet directly. The rubber ball was lifted indirectly. The tether provided the means for the rubber ball to tag along with the steel ball. With 2 parallel wires, the E force between the lattice and free electrons is the tether. The H force dictates where the electrons go, then the E force tethers the lattice yanking it in the direction of the electrons. To say that H is NOT responsible for the lattice moving is like saying that the magnet is NOT responsible for the rubber ball ascending. The electrons and the lattice are tethered via E force. But the H force is what moves the electrons, and is ultimately responsible for moving the lattice. The E force does indeed move the lattice, but the E force magnitude and direction is dictated by the location of the electrons which is dictated by the magnitude and direction of H. It's difficult to separate the 2 forces. But it is clear as day that H is what dictates the magnitude and direction of the displacement of the wires. E follows H. I know that E & H are inclusive, and neither is the cause of the other. But under these narrow conditions, H is ultimately in control, with E tagging along. H, however, is not more fundamental than E, nor less. They are inclusive. Does this make sense? BR. Claude |
| Oct27-09, 01:13 PM | #59 |
| Oct27-09, 01:52 PM | #60 |
Mentor
I may have to revise my answer to the Stern-Gerlach question in the light of the interesting paper that Academic linked to in post #56. (It might take me a while to find the time to digest it--hopefully someone more knowledgeable will chime in sooner.)
| Oct27-09, 02:04 PM | #61 |
Claude |
| Oct27-09, 02:11 PM | #62 |
Mentor
| Oct27-09, 03:39 PM | #63 |
| Oct28-09, 11:22 AM | #64 |
"The usual explanation
is that there is a change in the “potential energy” by an amount −2s ·B=−eB/mc, which implies that the magnetic field did work on the electron’s magnetic moment. However, if the electron has rotational kinetic energy," This is a quote from the paper. He states the conventional explaination, but he puts forward his own conjecture " rotational kinetic energy". |
| Oct29-09, 12:34 PM | #65 |
The forces of electromagnetism do work. Acceleration can occur along electric field lines and acceleration and also along magnetic field lines. However, because a cyclical process of doing work requires a changing magnetic field which in turns produces an electric field, electric fields are seen as crucial in order for work to be done. A changing displacement is sufficient for an electric field to do work, but not so for a magnetic field, which requires a change in magnitude in place (implying a change in electric field). Therefore when work is done using electricity or magnetism, an electric field ALWAYS comes into play, but same is not true for magnetic fields (because sometimes they are not used). It is a rare circumstance in the macroscopic world to have a system with truly constant magnetic fields (no induction) when electric fields are being moved relatively to each other...
| Nov12-09, 07:36 AM | #66 |
Hi
It might be out of date but I show here a interesting case, a charged particle attached on a elastic body, with velocity v in perpendicular direction, under magnetic field B in another perpendicular direction. | |wwwwwwwwwww○ ↑ v x B | Magnetic or Lorentz force pushes or pulls elastic body. It does work thus elastic energy would be stored. I state from this example that magnetic force does not work on FREE charge, but it can work on charge UNDER CONSTRAINT. The elastic body consists of multiple charged particles under electromagnetic interaction so we can say another way that magnetic force does not work on a system of SINGLE charge, but it can work on a system of MULTIPLE charges. Regards |
| Nov12-09, 07:57 AM | #67 |
Mentor
| Nov12-09, 08:08 AM | #68 |
OK, I will.
| |wwwwwwwwwww○ ↑ v x B | the direction of Lorentz force is ← or → according to the sign of charge ○ and it pushes or pulls the elastic body or the spring. Regards. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Magnetic fields do no work? How come...
| Magnetic fields do no work. | Advanced Physics Homework | 0 | ||
| Do magnetic fields do work? | Classical Physics | 17 | ||
| Why can't magnetic fields (that deflect electron beams) cant do any work to the beam? | Introductory Physics Homework | 6 | ||
| Electric fields, magnetic fields and Lorentz frames | Advanced Physics Homework | 5 | ||
| Magnetic fields inducing electric fields - turning on lightbulb with magnetic field | Introductory Physics Homework | 3 | ||
