How is high temperature reactor design different?
The discussion focuses on the differences between high temperature reactors (HTRs) and low temperature reactors, particularly in terms of materials, fuels, and operational temperatures. It explores theoretical and practical aspects of reactor design, including implications for efficiency and chemical processes.
  • Some participants suggest that high temperature reactors operate at significantly higher temperatures than conventional light water reactors (LWRs), which allows for the use of thermochemical cycles.
  • It is noted that the materials used in HTRs differ from those in LWRs, with specific mention of the need for materials that can withstand higher temperatures and radiation environments.
  • One participant details the operational parameters of pressurized water reactors (PWRs) and boiling water reactors (BWRs), highlighting their temperature and pressure constraints.
  • Different fuel types are proposed for HTRs, including cermet, metal fuels, and various uranium-based fuels, which may differ in form from the typical UO2 used in LWRs.
  • There is a question regarding the interaction of chemicals used in thermochemical cycles with the reactor, with a suggestion that a heat exchanger would be necessary to prevent direct contact.
  • Another participant reiterates the importance of finding suitable materials that can resist degradation at high temperatures and in contact with reactive working fluids.
Participants generally agree that high temperature reactors utilize different materials and fuels compared to low temperature reactors. However, there is ongoing discussion about the specifics of these differences and the implications for reactor design, indicating that multiple views remain on certain aspects.
The discussion involves complex considerations regarding material science and reactor engineering, with some assumptions about the operational environments and chemical interactions remaining unresolved.
Topher925
I think its common knowledge that the next generation of nuclear reactors are going to operate at much higher temperatures than current designs in order to get away from the Rankin cycle and take advantage of thermochemical cycles, but what is it that makes high temperature reactors (HTR) different than low temperature reactors? Does it mostly only have to do with the materials used to construct the reactor or are different fuels and control rod materials used?
The working fluid temperatures in high temperature reactors are higher than those in conventional LWRs, and the materials are necessarily different.
Let's consider LWRs.
PWRs (pressurized water reactors) operate with a primary circuit temperature of about 285-293°C inlet and about 325-330°C outlet at a nominal pressure of ~2270 psia. The fuel is subject to a number of engineering constraints under normal and off-normal conditions (NUREG-0800, Chapter 4.2). Basically the fuel is not allowed to melt (no centerline melting), must have less than 1% strain, and must not allow cladding lift-off in the event of design basis transients.
BWRs operate with the coolant at saturation conditions with a nominal core pressure of about 1045-1055 psia.
In LWRs the cladding material is an alloy of Zr and usually Zr-Sn or Zr-Nb with other alloying elements, e.g. Fe, Cr, Ni and others in lesser quantities. The fuel is UO2 or (U, Pu)O2, with additions of gadolinia, erbia or ZrB2 for reactivity control.
High temperature plants can use He (gas), Na or Pb (Pb-Bi) (liquid metal), molten salt or H2O. With respect to H2O, there is consideration of a supercritical water reactor which would have an operating conditions exceeding (374°C, 22 MPa, or 705°F, 3208 psia). Fuel materials could be cermet or metal fuel or UN, UC or (U,Pu)N or (U,Pu)C or possibly silicide.
See the concept here - http://nuclear.inl.gov/gen4/index.shtml
The operating environments of the Gen IV concepts are very challenging for the materials and engineering.
The idea is however to increase the temperature in order to increase the efficiency. In addition to producing electrical power, heat would also be used for chemical processes, e.g. hydrodgen production using the S-I process.
So, high temperature reactors do in fact use different U-based fuels than the typically low temperature reactors? And really what it all comes down to then is just finding the right materials that can handle those temperatures then right?
In the case of an S-I or Cu-Cl cycle, would any of these chemicals ever make direct contact with the reactor itself or would a large heat exchanger be involved?
The high temperature reactors do use U-235 (or Pu-239), and perhaps U-233 if a thorium cycle is employed, and these fuels would likely be in a different form than UO2, and would be clad in different alloys rather than the conventional Zr-alloys now employed in LWRs. And it is most definitely a matter of finding the right materials to resist degradation in the radiation environment at those temperatures and in contact with any working fluid that is not chemically inert, i.e. not He.
My understanding is that there would be a heat exchanger involved and the chemical reactor would be located ex-core.
  • · Replies 0 ·
  • · Replies 31 ·
  • · Replies 18 ·
