Finding the Volume of a Rotated Curve: Solving for the Correct Integral Limits
  • Thread starter Thread starter vipertongn
    Curve Volume
The discussion revolves around finding the volume of a solid formed by rotating a region defined by the curves x=8y and x=y^3 around the y-axis. Participants are attempting to determine the correct integral limits and setup for the volume calculation.
  • Mixed
  • Participants are exploring the correct setup for the integral, questioning whether the rotation should be around the y-axis or x-axis. There is discussion about the area of disks and the correct expression for the volume integral.
Some participants have offered guidance on the correct form of the integral and the limits of integration. There is acknowledgment of previous mistakes in setup, and some confusion remains regarding the integration process and the interpretation of the results.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a focus on ensuring the correct interpretation of the problem setup and the geometric implications of the rotation.
vipertongn
I'm suppose to rotate around y-axis...
x=8y;x=y^3 and y> and equal to 0
I was told to integrate (x^1/3-0)^2-(1/8x-0)^2
so... pi integral 0 to sqrt(512) x^2/3-1/64x^2 dx
I end up with 151.65 but that's incorrect can someone tell me what i did wrong and how to get the right answer?
Who told you this? This would be the volume of the region rotated around the x- axis. You said you wanted the volume of the region rotated around the y- axis. That would be the integral of [itex]\pi((8y)^2- (y^2^2) dy[/itex]
[itex]\sqrt{512}= 16\sqrt{2}[/itex]
Oh wait so it should be integral 64y^2-y^6 dy?
when i integrate that way it comes out negative
You are right. If forgot the squares (I have edited my response so I can pretend I didn't make thata mistake!). The area of a disk is [itex]\pi r^2[/itex] and you are taking the areas of two disks and subtracting them. The volume you want is [itex]\int_0^{2\sqrt{2}} 64y^2- y^4 dy[/itex].
Ahhh I'm confused ok I started with
x=8y
x=y^3
y>0
the limits of y are 0 to sqrt(512) and the limits of x is 0 to sqrt(8)
SO! Integral should look like 64y^2-y^6 dy Oh gosh nvm THANKS SO MUCH :D umm if i am correct its Rout-Rin right?
  • · Replies 27 ·
